Fast Flick "Edit in VideoStudio" not working
MLSM
Post by MLSM »
Hello, I have started my first slideshow in Fast Flick, ver 24.1.0.299. I'd like to do some additional editing in VideoStudio, but nothing happens when I hit that button beside the "save movie" button. I've saved the file as a .vfp as well but unable to open or import in VS 2021. All help much appreciated.
Re: Fast Flick "Edit in VideoStudio" not working
To the right of save movie I see an option to edit in video studio.
That should open the project on VS timelines
MLSM
Post by MLSM »
Yes, I have been clicking on that....nothing happens. I've waiting enormous amounts of time for it to open or load. I've tried it with VS 2021 already open....from close, etc. Nothing seems to happen at all.
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
So, under item 3 you clicked Save & Share, this opens another screen which gives the option to Save Movie (Blue) or Edit in VideoStudio (Green) clicking on Edit then opens your FastFlick project in VS.
VS can be open or closed when Edit is chosen, VS will automatically open
Not really sure what to suggest that does not involve Re-installing or a Reset
You could try renaming the folder 24.0 to ”24.0_old”
C:\Users\UserName\AppData\Roaming\Ulead Systems\Corel VideoStudio MW (x64)\24.0
Running Fast Flick will create a new 24.0 folder
The folder structure is hidden by windows, typing %appdata% will locate the roaming folder allowing you to navigate further. Or tell Windows to show hidden folders.
MLSM
Post by MLSM »
TKS for the attention all. Unfortunately, it seems I'll have to reinstall & see what happens.
I thought that may be the case, I did search the programs installation files but could not find a separate installation for Fast Flick, so yes you will have to re-install.
If you wish to retain your library structure you may be best to Export the Library, that will save a copy which can be imported once you have installed Video Studio.
By the way, how many FastFlick templates do you have, I only see 10 ish but know there another 10 that can be used, just needs to copy the template folders to another folder, I’ll dig out the details of those folder locations.
Good luck
