cannot find video filters!
entropyforce
I have vs9, i was working on a project and want to apply filters and all of a sudden they are gone. I tried uninstalling and reinstall but no luck. The filters dont even show up on the right anymore. they worked about 2 days ago. any ideas????
- michaeltee
- motherboard: HP 82F1
- processor: Intel Core I5 7400 3 GHz
- ram: 16 GB DC
- Video Card: Intel HD Graphics 630
- Hard_Drive_Capacity: 2TB Hybrid
- Monitor/Display Make & Model: Samsung S24D300
- Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Once VS9 has been installed, these are normally stored in a folder named vft_plug and each filter has an individual file extension of .vft (average.vft, balance.vft, etc...).
For starters you might check your VS9 directory (typical path) C > Program Files > Ulead Systems > Ulead VideoStudio 9.0 > vft_plug and make sure they are installed. If you don't see them, try a Windows wildcard search on *.vft and see if they were installed in a different location. If the search doesn't find anything it most likely means they are not installed.
In that case, I would consider a full uninstall of VS9. After the uninstall, reboot and manually check to make sure the Ulead VideoStudio 9.0 directory and all of it's contents were removed. If not, delete the folder. Next, reinstall VS9 from scratch, reboot, launch VS9 and check to see if your filters are OK.
-Mike
-Mike
entropyforce
the vtf filters are in the folder in the location you described. They did work fine now the video filter option isnt available on the right. any other ideas? reinstalling doesnt seem to help. is there a secret file that doesnt get deleted when you uninstaLL? maybe i can delete the preferences manually?
- michaeltee
- ram: 16 GB DC
Hmmmm... VS9 should make the association to your vft_plug folder by default. Unfortunately I don't know of any hidden procedures but many of the video software publishers offer a tool that deletes all related registry entries, giving you the opportunity to perform a true "clean" install. You might try posting a new topic to see if anyone knows if Ulead offers a utility of that type. If not, tech-support might be able to help you manually delete the regestry items although I'd imagine it would be quite a task. I wish I could be of more help but that's all that comes to mind so far.
-Mike
-Mike
THoff
Magiros
I had a similar problem, seem to happen after I applied the patches for VS9. I was able to correct it by only reinstalling VS9 content packs (normally saved to the "C:\Program Files\Ulead Systems\Ulead VideoStudio 9.0\SmartDownload" directory). Note that when you reinstall, any video & sound clips etc stored in the general libraries are blown away.
Hope this helps... regards John.
treble
Read this posting re:- video filters
http://phpbb.ulead.com.tw/EN/viewtopic. ... ht=filters
Hope this helps
Trevor
I have found a solution on my own:
From an XP user profile that works correctly, look for the file Vfilter.rsf located in C:\Documents and Settings\USERXX\Application Data\Ulead Systems\Ulead VideoStudio\9.0 or the location specific to your system, and copy it to the correspondent location of your XP profile, C:\Documents and Settings\YOUR-USER-NAME\Application Data\Ulead Systems\Ulead VideoStudio\9.0
Thats all you need, remember to make a backup of the original file in case it do not work in your system.
Giancarlo
_________________
G Ariza
VS9 User
Thanks Gariza
Hope this helps
Trevor
treble
