Failure to install inUbuntu 21.10
vlad88sv
operating_system: Linux
Corel programs: AfterShot
Post by vlad88sv »
Hi, I'm getting the following error while trying to install:
Code: Select all
sudo apt install ./AfterShotPro3-system-QT.deb
...¡Error!
E: Problem parsing Provides line of aftershot3x64:amd64=370446:3.7.0.446
E: Problem with MergeList /home/vladimir/Descargas/AfterShotPro3-system-QT.deb
any suggestions? thank you
grubernd
System_Drive: N/A
Re: Failure to install inUbuntu 21.10
Post by grubernd »
vlad88sv wrote: Mon Dec 06, 2021 5:37 pm any suggestions? thank you
https://www.darktable.org/
.. that's what I did in 2020 after ASP failed to install on my Linux box the first time in 16 years.
Bibble since 2004. Aftershot until 2020. From then on darktable.
papazee7816
Post by papazee7816 »
I'm very late to this discussion but I'm just now switching my workflow to Linux completely and I'm testing ASP against Raw Therapee and Darktable. Many years ago I was a big fan of Bibble Pro. Regardless, just wanted you to know that I was able to install ASP 3 on my Ubuntu 21.10 installation using dpkg:
sudo dpkg -i AfterShotPro4-system-QT.deb
sudo apt install -f
I've had a couple of crashes while testing the catalog import feature but at this point, I'm suspecting corrupt image files until I know better.
Just wanted to let you know it can be installed on 21.10. Seems to work pretty well but for the exceptions I mentioned.
Greg Z
Lee's Summit, MO
