Effects Manager timecode in PAL
v2to8
I'm working on a project in PAL. The timeline works in 25fps as does the preview monitor but the effects monitor timecode is 29.97fps (NTSC). Is this bug known about by the beta team? Or am I doing something wrong
Thanks.
Downstairs Video
OK I confess, I use PAL, but I cannot find the fps in the timecode you refer to.
One thought - The clips you are importing to use, are they the default ones in the Media Library? Because they are NTSC 29.970 and 720x480
instead of the 720x576 and 25fps you would have it set to. If you are using this footage try importing some genuine PAL and see what you get.
v2to8
To be precise, it is not drop-frame but non-drop-frame timing at 30 fps and it is in NTSC, as well.v2to8 wrote:whereas the effects manager window shows a different 29.97fps timecode....
