Hello,
I am getting Runtime Errors very often when I try save or save as , even after 2 minute works. It is imposible to continue working. This has emerged in recent month. Before, it was working satisfactorily. It gives warning mesage as follows:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files...
R6025
-pure virtual function call
My health problems prevents me conducting detailed scientific searches. I will appreciate you kind help on this issue.
Runtime Error R6025- pure virtual function call
Re: Runtime Error R6025- pure virtual function call
Unfortunately, I have never seen that specific error message before. However, I have found this specific suggestion for it -- though I can't guarantee it will resolve your problem. I assume in the meantime that you have rebooted the computer since receiving the message but this did not rectify the situation:
"Get Rid of Runtime Error r6025 on Windows
You may observe this Windows runtime error r6025 when a program performs an invalid function call to a member function which is virtual. As a result, the compiler will shoot up an error during the build phase of that program. You may also receive this error if you haven’t installed the program properly. It might happen that some files get corrupted during the installation process. Want to know more about how to resolve this error r6025 on Windows? Go through the under-mentioned steps in order to combat the aforementioned issue.
Shut down the program by closing the program processes. After that, press the combination of Alt, Ctrl, Del keys in order to open the Task Manager.
Navigate to the Program processes present under the Processes tab present in the Task Manager. Now, hit on the End processes. After that, you have to close the Task Manager.
Move to the Uninstalling a Program window by following the below path.
Start > Control Panel > Uninstall the Program
After that, select the program that is displaying the error and click Uninstall.
Remove the respective program files of the software after the process of uninstalling gets over.
Now, hit the Start option and press Enter after providing “cleanmgr” in the search bar.
Select the drive where you have installed the program. Then, hit the OK option. Now examine all the options present under the tab Files to delete and hit the OK option.
Then, reboot the PC after the removal of files.
Finally, reinstall the program to examine whether the error R6025 pops up or not."
@Ken Berry I intentionally waited a few days for this feedback. After reinstalling it works pretty well and stable just like that at the beginning. Thank you.
