While editing and using the cursor to move around it changes to a cross and I cannot continue to edit.
Files used m2ts. Tried Storyboard mode and it freezes. I never have seen such behavior before. No problem with Power Director. Sample file: https://www.sugarsync.com/pf/D1814182_040_952850140
Transitions do not work-it's crazy. This was a reinstall too.
VS 2021 gone crazy
pepegota
- motherboard: ASUS TUF Z390-Plus
- processor: Intel i9 - 9900k
- ram: 64 GB
- Video Card: GTX 1660 6GB
- sound_card: On board sound
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Ben Q, "21" LCD
- Corel programs: VS 2018, VS 2019, VS 2020
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: VS 2021 gone crazy
Your sample file is a JPG (attached). What is it supposed to demonstrate? tletterpepegota wrote: Sample file: https://www.sugarsync.com/pf/D1814182_040_952850140
pepegota
- ram: 64 GB
Try this: https://www.sugarsync.com/pf/D1814182_040_952805529
I restored an image backup and the same problem exists. The arrow cursor turns to a cross and I cannot function. It looks like my computer does not like VS. After more than ten years of use, I may have to go elsewhere. Transitions do not work also-a mess.
gewb
- motherboard: MSI Pro B550-VC
- processor: AMD Ryzen 7 5700X
- Video Card: ASRock Radeon RX 6650 XT
- Monitor/Display Make & Model: LG 24MK430
- Corel programs: 2018, 2021, 2023 Ult.
Open a Command Prompt as Administrator. Type in:
sfc /scannow
Then press the Enter key. It will take a couple minutes to run as it looks for system file errors and tries to correct errors.
sfc /scannow
pepegota
- ram: 64 GB
No problem with SFC. Some functions of VS work, motion control, split sound, but using it in total is not an option. However, using it with Power Director, which has no problems, I have a hybrid system. At least I can function. This problem exists on three computers, i9,i7 and a laptop. The i9 and the laptop are on Win 10 and the i7 is on Win11. "Something rotten in the state of Denmark."
I restored an old image backup from one month ago and now VS is working as it should. I must have picked up something that VS did not like, but all is back to normal.
If anything this proves, is the wisdom of computer image backups.
pepegota
- ram: 64 GB
Dead in the water. VS crashes and freezes. Reinstall to no avail.
I just installed an old backup image file, from a month ago, that saved the day. I must have pickup something that VS did not like.
If anything, this shows the value of an image backup! It's good to be back.
