Line left side of ISO file when played via VLC
Re: Line left side of ISO file when played via VLC
Candy, I have managed to create a different Mpeg2 profile that appears to render without the lines,
Unfortunately it only works when using interlacing Lower Field First
I believe you are using Frame Based aka Progressive or using Upper Field.
but need some info from you and you to test.
Can you give the properties you are using to create the Mpeg 2 , interested in the interlacing, frame based or field order.
The new profile may mess up your project so test with a copy.
Please use this video clip ( one second black clip) to create a new Profile
Open Settings - Movie Profile Manager
Select mpeg2 as the Format
Now select the Add option
browse for this video clip called
Candy Mpeg2 Profile LFF.mpg
Now Close the panel
Go to share Mpeg2 where the new profile should be available via Mpeg2 profiles.
Otherwise add the clip as the first on the top timeline.
Then Share Same as First Video Clip
Candy Mpeg2 Profile LFF.zip
(6.64 KiB) Downloaded 46 times
I have come to the conclusion that there is an issue with the Mpeg2 render engine
Not only does standard DVD using Mpeg2 suffer but also affects AVCHD files from share AVC/H.264 allow us to choose to use Mpeg2 or H264, using Mpeg2 as the video format also shows the white lines apparent when using 1920 x 1080 HD frame sizes.
cdoughertycd
motherboard: ASUS PHTD DELUXE
processor: 4 Core 2-93 gigahertz Intel Xeon
ram: 36 GB
Video Card: AMD Radeon HD 7700 Series
sound_card: AMD HD Audio
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Samsung S24B300
Corel programs: many back to VS 5, all up to 2022 Ult
Post by cdoughertycd »
Trevor: I'm trying your steps - at "browse for this video clip called Candy Mpeg2 Profile LFF.mpg, File Path is grayed out, only box "Profile Name" is available. Do I just type in "Candy Mpeg2 Profile LFF.mpg"? I know where I saved it but can't browse for it. Should I continue with my test? I am happy to, just stumped at not being able to browse for the "....LFF.mpg" file.
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Post by Davidk »
Trevor,
bug the problem so it might get some attention @
- 2021 sp3 - there was some thought being given to that . last update nearly 8 weeks ago
- CVS2022??
cdoughertycd wrote: Wed Nov 03, 2021 10:47 pm Trevor: I'm trying your steps - at "browse for this video clip called Candy Mpeg2 Profile LFF.mpg, File Path is grayed out, only box "Profile Name" is available. Do I just type in "Candy Mpeg2 Profile LFF.mpg"? I know where I saved it but can't browse for it. Should I continue with my test? I am happy to, just stumped at not being able to browse for the "....LFF.mpg" file.
You have to select the small box containing the dots, a little greyed out
As my image
Otherwise add the video as the first clip on the timeline and use Share - Same as First Video Clip.
But as i say it is Lower Field First and I think you are using Frame Based
Davidk wrote: Wed Nov 03, 2021 11:17 pm Trevor,
- CVS2022??
Thanks David
I have already e-mailed Yvonne and Nick last Monday, no reply so far
But yes I was considering using the bug report option
post updated -- bug report submitted
cdoughertycd
ram: 36 GB
Update:
I just got this from Corel Support - I'll give it a try tonight:
Candy
Mr. / Ms. ,
Thank you for contacting Corel Customer Support Services. My name is Vidhya and I have been assigned to your ticket.
I do apologize for the inconvenience happened to you. Let me help you to fix the issue as quick as possible.
Yes, still if you have the issue.
you can backup your files using the below steps.
To save the VideoStudio library:
• Click Settings
• Click Library Manager
• Click Export Library
• Select a destination folder or create one
• Click the OK button
>Kindly uninstall the VideoStudio ultimate 2021 on programs and features, then delete the file name says VS2021_install.exe, in windows explorer if you have any.
> Reboot the computer
>And then to reinstall the VideoStudio 2021 by clicking on VideoStudio 2021 on the below link:
http://www.videostudiopro.com/en/pages/download/ with the serial number.
To Import the VideoStudio Library once reinstalled
• Click Settings
• Click Import Library...
• Select the destination folder that holds the exported library information
Let me know if that works for you.
Please do not hesitate to contact us with any further questions.
Vidhya
When you run the program installer you should choose a new empty folder as your download folder, this will provide you with the latest installation files.
I installed video studio using that process just prior to testing this issue.
I doubt that re- installing the program will fix this problem, but give it a go.
Oh........ you will have to first uninstall the program to allow you to download any files
cdoughertycd
ram: 36 GB
Ok, thanks Trevor. I'll let you know and I too don't think it will work but worth a try.
cdoughertycd
ram: 36 GB
Aside from the left line issue on MP2 files in VS 2021, I was just at our local camera store (Samy's Camera in Pasadena, CA). Video guy said I could get better quality burning to Blue Ray, but I'd need the burner and Blue Ray discs. I clicked on DVD burn/Blue Ray in VS and it's asking for a fee, $7.99 or thereabouts, probably for access to Blue Ray burning. At my stage (age, lol) I'm not going to invest in a burner and discs for this. I'm assuming by now most of the non-tech people who want their performance on a DVD would by now have Blue Ray players but maybe some not. Do you all ever have need to burn to Blue Ray discs?
FWIW I bought a Blu-Ray burner at least 5 years ago, plus the Corel plug-in for burning, and have quite a supply of blank discs. But with the advent of streaming I have not burnt an actual Blu-Ray disc in at least 4 years... In fact it is now difficult even to find blank BD discs here in New Zealand these days.
The Pasadena guy was right in that BD disc are much better quality than standard DVDs. However, if you distribute the discs, your recipients would need to have Blu-Ray players to play them...
cdoughertycd
ram: 36 GB
Ken, exactly, that's what the camera store guy said. The people who want their performance on a disk I'm sure are totally non tech, lol. Camera guy said tell them to download the MP4 from the Dropbox onto a thumb drive, then the question would be "how do I download to a thumb drive?" LOL
Davidk
ram: 16Gb
Post by Davidk »
A thumb drive plugged in to a PC is just another "save to" location, or just use explorer to specify that in a copy operation. Once done, take it and plug in to the TV monitor and play it from there. That assumes the monitor has a usb connection for that - most large screen devices and smart TV's do. If the TV or monitor doesn't have that sort of facility - a DVD is what you are left with.
cdoughertycd
ram: 36 GB
Ok, thanks David, I look at the back of my TV and will try.
cdoughertycd
ram: 36 GB
Update - Per my Nov 4, 10:56 am comment above with instructions from Corel Support to uninstall VS 2021 and reinstall, also importing my library - it did not work, still have the left side line on MP2 render.
Candy
