Cannot remove pick
jlovda
motherboard: Dell XPS 8700
processor: i7-4790
ram: 20 GB
Video Card: GTX 1050 Ti 4GB
Corel programs: PSP Ult. 2021, 2020, 2018
Cannot remove pick
Post by jlovda »
I have been fiddling with a file to try and cut out a little portion and paste it onto another image. Somehow the image now has a "pick" rectangle around it that I cannot remove. I have tried saving the file and reopening it but the pick still remains. How do I remove that pick so I can create a different pick area? If I try grabbing a corner, the area just gets squeezed. Help.
John
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Cannot remove pick
Post by LeviFiction »
If it's actually the bounding box of the pick tool, then just select a different tool. That box will show up around any selection or layer while the pick tool is active.
If it's a selection rectangle then go to Selections -> Select None or hit Ctrl + D
jlovda
processor: i7-4790
ram: 20 GB
Post by jlovda »
I tried Selections/None but it does not go away. If I pick something like Clone the box disappears but as soon as I hit the Pick Tool again, the same box around the outside of the image comes back. The Pick tool seems to be locked. Is it normal for a saved image to retain all of the previous editing instructions?
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
What do you mean when you say you want the Pick tool to pick another area? The Pick tool, when selected as a tool, will place the Pick bounding box around whichever layer is selected in the Layer's palette. So if you have that pasted image pasted into another image as a layer and if that is the layer selected in the Layers palette then the pick tool will still put its box around it. If you want it to pick another layer then make that other layer the selected one in the Layers palette. The Pick tool is not a Selection tool.
JoeB
Using PSP 2019 64bit
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
You don't use the Pick tool to 'pick an area to copy|cut and paste', you use a Select tool to 'select an area to copy|cut and paste'.
"Is it normal for a saved image to retain all of the previous editing instructions?": In the most recent versions of PSP, under File/Preferences/General Program Preferences... > Miscellaneous you'll find the option "" Save edit history to image metadata (JPEG, TIFF, PSPIMAGE)". Check or uncheck that. Is that what you meant?
jlovda
processor: i7-4790
ram: 20 GB
Post by jlovda »
Thanks for all your comments. I went back to my original image and started over. It worked fine.
Forriner......... Yes, that is what I was asking. Thanks.
