Shortcut Issues PSP 2022 Update
Hi there,
My shortcut keys have stopped working since psp 2022 update.
Eg: Ctrl + Z, Ctrl + D, Shift + S .... etc
I think that the shortcut keys were also labelled next to each item in the menu's which also appears to have disappeared.
(Eg: Shift + S next to resize in the image menu )
There is a few shortcut keys that do work such as Ctrl + P , Shift + A etc but these appear to be interface related rathe than object manipulation shortcuts.
Any suggestions would be appreciated as going through a menu to press undo is very long winded
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: Shortcut Issues PSP 2022 Update
Launch PSP again and it will work.
They are working on my updated version.
I tried closing and closing background process and reopening but still no joy.
Should I reinstall and deny the patch?
In keyboard Map, all the category "edit" keys are nulled. (I have never edited them before)
+other categories
+other categories
I Just tried a reset and no joy either, Is there a default file for shortcuts?
Jean-Luc
It seems you will need an uninstall and reinstall.
Do the uninstall with Windows uninstaller. After uninstall, shut down the PC, launch again, and reinstall.
Help / Keyboard map seems to be incomplete. For example, Ctrl+V is not listed but is assigned. You may assign the shortcuts manually:
View / Customize / Keyboard
Uninstall >repair Does not fix this.
Reinstall works
Thank you all working now
Reinstall works
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
I use PSP2019 and, unless they changed it (or if I customized it and don't remember) there is an Undo and Redo button on the standard toolbar.
JoeB
Using PSP 2019 64bit
JoeB
I don't think there was either before I reinstalled psp (I was having to go to "Edit>Undo")
but since reinstalling there is one on a toolbar that I have not closed:
Jean-Luc
They exist for many previous versions.
