Cannot play video from IMGP7358.MOV file of Pentax K-3 camera
kapitan
motherboard: HP ZBook 15 Fury G7
processor: QuadCore Intel Core i5 10300H 2_5 - 4_5
ram: 32GB
Video Card: AMD Radeon RX 5500M 4080 МБ
sound_card: Intel UHD Graphics 1
Hard_Drive_Capacity: 2_5 TB
Monitor/Display Make & Model: BenQ BL2420PT QHD Designer Monitor
Corel programs: Paintshop Pro X9 Ult.,VideoStudio2020Ult
Post by kapitan »
Hi. Dear friends.
The official Corel VideoStudio Ultimate 2020 (Corel VideoStudio 23.3.0.646 64bit Ultimate) cannot play video from the IMGP7358.MOV file of the Pentax K-3 camera.
There is sound. Tell me what to do? The file cannot be downloaded (a message is displayed - ERROR.Invalid file extension IMGP7358.MOV) .
I give the download link:
https://drive.google.com/file/d/1fQqg9s ... sp=sharing
I also attach its properties in text format.
IMGP7358.MOV.MediaInfo.txt
(4.62 KiB) Downloaded 42 times
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: Cannot play video from IMGP7358.MOV file of Pentax K-3 camera
Post by RobertOZ »
Not a problem, your clips can be added to the timeline and the video
and audio play correctly
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
No problem on VS2019 also.
Kapitan, Do you have QT installed?
Panasonic X900m, VXF1
kapitan
ram: 32GB
Post by kapitan »
Robert thanks.
But it looks like this to me.
What video card are you using?
I have AMD Radeon 5500M 4Ggb.
kapitan
ram: 32GB
Post by kapitan »
asik1 QT 7.7.9 is installed.
kapitan
ram: 32GB
Post by kapitan »
I solved the problem: I set NTSC in Settings-Preferens-General (instead of PAL).
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Both Robert and I are in PALand.
You should also better use PAL as this video is 25fps.
kapitan
ram: 32GB
Post by kapitan »
Got it. But I can't do that. You can take screenshots for:
Settings - Preferences -General
Settings - Preferences -Edit
Settings - Preferences -Capture
Settings - Preferences -Perfomance
Thanks.
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Post by Davidk »
You don't say what country you are in (your personal profile) and that directly affects the playback system and quality gained when using CVS. For example, Europe (except Russia and France), South Africa and countries in the mediteranean and some of SE Asia inc Australia use the PAL standard for image display. The USA, Canada and the americas, and Japan all use NTSC. NTSC was the original colour standard for TV, and cynics call it "not twice the same colour" because it had colour variation/stability problems. The PAL system was evolved in Germany to correct that, and provide a better image resolution. The stability of the image (rolling vertically, or not) was directly impacted by the power line frequency (25 or30hz) the display was drawing energy from, and altho the times have moved on the display standards for multiple source material (broadcast TV, the internet, or computer display) are still in use. So which one in use for your country is important. When installing CVS, the very first default of the installer is NTSC. If that is not your country, change to PAL. Leaving it "as is" because you know no better is defaulting your video system to a display format that's used in the USA.
You can change the TV display system in preferences and you have done that - with a successful result with the imported camera clips as posted.
A mov format is like many others a container for the specifics needed to play the clip. Those specifics do vary between manufacturers, and not all are supported by video software. Your results suggests that the imagery recorded by your camera is somehow set to NTSC, quite possibly the frame rate. If an investigation doesn't allow change to the 25fps format used by a PAL configured CVS, and the camera manufacturer won't or cannot help, then maybe you should pass the camera imagery thru the handbrake program (free) and simply change the frame rate to 25fps in the result.
kapitan
ram: 32GB
Post by kapitan »
Davidk thanks for teaching.
I accidentally shot it in FHD (1920x1080) resolution and saw that it does not play video at any settings.
But there is sound. In the past, the file had a HD resolution (1280x720) and everything was reproduced there when set to NTSC.
Why? File link:
https://drive.google.com/file/d/1ElY8Gk ... sp=sharing
Try it if you can. Thanks anyway.
canuck
operating_system: Windows 8.1
Post by canuck »
Access Denied to your link
kapitan
ram: 32GB
Post by kapitan »
RobertOZ
Post by RobertOZ »
Your clip plays fine in VS2021, but audio is just background noise, is that correct
kapitan
ram: 32GB
Post by kapitan »
Yes.
What could be the reason that my video does not play?
kapitan
ram: 32GB
Post by kapitan »
Installed the trial version of Corel VS 2021.
EVERYTHING WORKS!!!
All MOV files are playable without any problem!
