Can I output RAW files?
OldNick
Corel programs: PSP Pro 2018 32 bit and 64 bit
Post by OldNick »
If I process say, a CR2 file in ASP, then try to export it, I can only choose other formats. I have been told that RAW files have a heap of other information that stores the editing history, that will be lost if I save as other formats. But in ASP AFAICS I have only 3 choices, none of them "save in original format" or whatever.
There seems to be no way to even save for later processing in ASP.
What is the story here, please?
Thanks for any help.
Nick
Win 10 64 .... PSP 2018 32/64 bit....Video Studio Ult 2022
Voiceofexperience
motherboard: ASRock
processor: AMD FX-4300
ram: 32 gb
Video Card: AMD Radeon 7 200
Hard_Drive_Capacity: 5 tb
Monitor/Display Make & Model: LG S-IPS
Corel programs: None - I'm fussy.
Re: Can I output RAW files?
Post by Voiceofexperience »
You're fundamentally missing the point of Raw, Nick.
Think of it as a film negative: you never, ever change the negative, you take "copies" of it, which you then manipulate. But the negative stays exactly the same.
That's precisely the model for Raw files. You convert and export them into files that allow further processing, but the Raw original remains completely unchanged and untouched, as it came off the camera.
This is basic stuff, and you really should consider educating yourself about it.
Whoever told you that can safely be completely ignored going forward: nothing is lost, precisely because the Raw file is unchanged. Anything that is in the Raw file when it came off the camera, is there forever.
And no, no "editing history" (apart from in-camera adjustments) is written to a Raw file.
Ever.
That's what a converter's database - or XMP files - are for.
Note the phrase "non-destructive editing": if you start changing the data in a Raw file, it's not non-destructive editing any more.
OldNick
Post by OldNick »
Gah! PSP has a "save image settings" check box when it goes through the RAW process stage... that is set to off by default...sheesh!
I set it to on and suddenly xmp files appear. BAH!
Nick
