PSP 2022: How to hide tutorials in central area after start?
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
is there a way to remove this?
Kathy_9
Hard_Drive_Capacity: 2TB
Re: PSP 2022: How to hide tutorials in central area after start?
Post by Kathy_9 »
No, there is not. However you cannot see them as long as you have an image open.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
You may replace the thumbnails with yours or remove them.
See here (use Google webpage translate):
http://www.paintshoppro.fr/viewtopic.php?p=16289#p16289
Radim
ram: 4GB
Post by Radim »
Thanks, replaced 8 times.
Still it needs some [x] Switch off for next update.
EDIT:
with program strings64.exe from https://docs.microsoft.com/sk-sk/sysint ... ds/strings
Code: Select all
strings64.exe -s "C:\Program Files\Corel\Corel PaintShop Pro 2022 (64-bit)" > c:\psp2022.txt
Code: Select all
C:\Program Files\Corel\Corel PaintShop Pro 2022 (64-bit)\Languages\EN\Corel PaintShop ProRC.dll: Workspaces
C:\Program Files\Corel\Corel PaintShop Pro 2022 (64-bit)\Languages\EN\Corel PaintShop ProRC.dll: AI Portrait Mode
C:\Program Files\Corel\Corel PaintShop Pro 2022 (64-bit)\Languages\EN\Corel PaintShop ProRC.dll: Replace Background
C:\Program Files\Corel\Corel PaintShop Pro 2022 (64-bit)\Languages\EN\Corel PaintShop ProRC.dll: AI Style Transfer
C:\Program Files\Corel\Corel PaintShop Pro 2022 (64-bit)\Languages\EN\Corel PaintShop ProRC.dll: Frame Tool
C:\Program Files\Corel\Corel PaintShop Pro 2022 (64-bit)\Languages\EN\Corel PaintShop ProRC.dll: Layers
C:\Program Files\Corel\Corel PaintShop Pro 2022 (64-bit)\Languages\EN\Corel PaintShop ProRC.dll: Selection
C:\Program Files\Corel\Corel PaintShop Pro 2022 (64-bit)\Languages\EN\Corel PaintShop ProRC.dll: Video Tutorials
Radim
ram: 4GB
Post by Radim »
So to completely "hide" tiles and texts I edited one DLL and cleared a few texts and replaced 8 tiles (.png) with its transparent version. Result is below.
PS: Do make a backup of original DLL.
psp2022 How to hide tutorials in central area after start.zip
(2.48 MiB) Downloaded 311 times
spitfrog
motherboard: NZXT N7-490
processor: Intel I5-10600K 6C 12T 4_8GHz
ram: 32 Go DDR4
Video Card: Radeon RX 6750 XT 12GB
sound_card: AE-5 Plus
Hard_Drive_Capacity: 6To
Monitor/Display Make & Model: AOC Q3277 + Wacom Intuos 3 A4
Corel programs: PaintShop
Post by spitfrog »
Thanks Radim, your procedure works perfectly on another language. It's just that string64.exe truncates words with accents, not easy to find words like "échoué" (failed in english) which displays only "chou", but in this case there was no difficulty to find the expressions. Good work ! :D
kjd03842
Hard_Drive_Capacity: Hampton
Post by kjd03842 »
I've managed to hide the images with the transparent .png files, so the appearance on startup is better. But the links are still there.
What did I miss? Something about modifying the text within the dll using the strings command? Anyone able to walk me thru it a little better? Thanks
CDPSP Sandy
Corel programs: PaintShop Pro
Post by CDPSP Sandy »
I found the easiest way is to just have the organizer docked at the bottom of the workspace and leave it there. It is not intrusive and when opening PSP the workspace is always clear.
Jean-Luc
Post by Jean-Luc »
Hi Sandy,
I tested your suggestion but it doesn't work. The central thumbnails are still visible.
CDPSP Sandy
Jean-Luc, when you have the organizer at the bottom, is it open or closed? I have mine docked but closed. Check when it is open - on the left side there is an X for closing it, A push pin and also a little triangle. Check the push pin - which way is it pointing? Down or to the left? Have it pointing to the left. That is how I have mine set up and I don't have the images in the centre. If I change that push pin to pointing down, then the images return.
Jean-Luc
Post by Jean-Luc »
Hi, Sandy
the tutorial's thumbnails are still visible when my Organizer is docked or not, push pin down or left.
You have perhaps another setting that I don't apply.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
EDIT: So I originally asked what Sandy's screen resolution was thinking maybe it was a rendering error caused by something obscure, but nope I too can get the tutorial images to vanish by opening the organizer and setting it to auto-hide. I have it docked to the bottom and specifically chose "Auto-hide" from the menu. Sometimes they come back, but it is working. Interesting bug.
EDIT EDIT: Screen resolution or, more specifically, the size of the PSP window might also play a role. I always have PSP set to 1240x720 for recording purposes. And with it like that the organizer trick works, but if I go full screen on my 1920x1080 monitor the tutorials come back. So I did some more tests, once the window gets tall enough the tutorials show up. For me that's around 820 or 821 pixels high. Anything smaller and the tutorials vanish.
Jean-Luc
Post by Jean-Luc »
I am working at 1920 x 1080 and never smaller. If I reduce the size of the PSP window to the smallest possible, the thumbnails never disappear.
While I was testing I enlarged the Organizer to half the height of the workspace, I get some screen refresh bug (see attached).
ram: 6 GB
The auto-hide on the pallete is important for this bug.
CDPSP Sandy
My screen resolution is 1920 x 1080 and I do have the auto hide selected.
