I'll admit I do not work much with VS, but I found when trying to do some color work, it is impossible.
Soon as I scroll the play-head to a different frame, color mode is OFF and must be re selected.
What I'm missing?
(play this animated gif, I used Screen2gif I recommended not long ago)
How do you work on the Color panel?
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Panasonic X900m, VXF1
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: How do you work on the Color panel?
Have similar issue, as soon as I move the cursor, the screen reverts back to whats showing in the library, but if play is selected from under the preview screen, then all the color options can be adjusted, touching the cursor causes it to revert back
gewb
- motherboard: MSI Pro B550-VC
- processor: AMD Ryzen 7 5700X
- Video Card: ASRock Radeon RX 6650 XT
- Monitor/Display Make & Model: LG 24MK430
- Corel programs: 2018, 2021, 2023 Ult.
It's not justwhen in the color panel. Any time in the edit mode, any panel, if the position cursor is moved the program kicks out of the edit mode. Actually makes sense to me.
gewb
