Uninstalling AutoDetector
mclamais
I installed the demo of CD & DVD PictureShow 4 and since uninstalled it. But the Ulead AutoDetector is still there. How do I remove this?
remove autodetector
Are you using WinXP? If you're using it, go to Start>Run type msconfig. The system configuration utility will appear then go to startup. Look for C:\Program Files\Common Files\Ulead Systems\AutoDetector\monitor.exe then uncheck the box beside it. Click OK then restart. ^_^
†bryave
