VS 2020 Ultimate Crash on Startup!
Ronin-X
motherboard: MSI MPG Z390 Carbon Pro AC
processor: Intel i9 9900K
ram: 32GB
Video Card: EVGA FTW3 GTX 1080 Ti
Hard_Drive_Capacity: 8+GB
Monitor/Display Make & Model: Samsung Odyssey G7 32"
Corel programs: PSP 2021 Ultimate, VS 2020 Ultimate
Re: VS 2020 Ultimate Crash on Startup!
Post by Ronin-X »
RobertOZ wrote: Fri Oct 08, 2021 12:24 am Just a thought, disconnect from the internet, then launch VS, it's possible that with the internet connected it's looking for something it can't find
It was a nice thought, unfortunately it didn't change anything!
Custom Build - OS: Windows 10 Pro 64bit / Motherboard: MSI MPG Z390 Carbon Pro AC / CPU: Intel i9 9900K / RAM: Corsair Vengeance Pro RGB 32GB DDR4 3200 / Graphics: EVGA FTW3 Geforce GTX 1080 Ti / Capture Card: Elgato 4K60 Pro MK.2
Ronin-X
ram: 32GB
Post by Ronin-X »
RobertOZ wrote: Thu Oct 07, 2021 9:14 pm Immediately apply for a refund, I believe you have 30 days, once received
Done!
glus
motherboard: MSI Z390
processor: Intel i9-9900K
Video Card: NVIDIA GeForce 2060
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Acer X233H
Corel programs: VideoStudio, Pinnacle Studio
Post by glus »
Hi Brian,
Sent you a PM.
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Hopefully, now with Corel directly involved, a solution will be quickly found
Brian, please keep us updated with progress
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Post by Davidk »
Maybe someone could explain the difference between a "clean boot" and a "clean install"??
Another possibility is that there is something left in the registry that's causing this. What, don't know. Example cited;
the desktop I am running this on was once win7. I had 4 versions of CVS on it, but after migrating in place to win10, not one of them worked correctly when opening Share: the PC jammed up. A clean install of win10 fixed that by starting with a whole new registry file, but broke so much of the PC environment (printer, NAS and local network) that I elected to live with a migrated platform and started using PD18 for editing. I theorised that all prior installed versions of CVS had left something in the win7 registry (there were 884 video studio entries in the migrated registry when no CVS version was installed and cleaned up) and the upcoming CVS 2021 would be the first version that had NOT been first installed on win7 and maybe that would be different. AND it was. when released, CVS 2021 installed and runs fine on the migrated win10 PC, no issues at all
RobertOZ
Post by RobertOZ »
David,
A clean boot is starting the computer with only the most essential files reqd. by the system
A clean install is the complete reinstallation of the OS, with 2 options, "keep my files" or remove everything
Davidk
ram: 16Gb
Post by Davidk »
Robert,
Maybe it's just terminology: a clean boot looks like a safe mode start.
Ronin-X
ram: 32GB
Post by Ronin-X »
Davidk wrote: Sat Oct 09, 2021 8:51 am Robert,
A clean boot allows for more control over what is running and what isn't! More effective for troubleshooting from my perspective.
Safe boot is a boot with predetermined settings. the only advantage to a safe boot as for what I understand is it allows you to boot with or without a network.
Ronin-X
ram: 32GB
Post by Ronin-X »
RobertOZ wrote: Fri Oct 08, 2021 8:49 pm Hopefully, now with Corel directly involved, a solution will be quickly found
I ended up just doing a fresh install of Windows and it solved the problem!
