Windows 11 was built to run most Windows 10 apps. If you are having problems, does your PC meet the Windows 11 requirements? Did you run the Windows 11 PC Health Check? https://www.howtogeek.com/737021/how-t ... indows-11/
As far as drivers that problem usually happens on older PC's when drivers have not been kept updated. Did you update your drivers prior to upgrading?
If you try to install 11 without having an eligible PC, you may be asking for trouble -- not only a slow processor, but no Windows support. Windows 10 will be supported until 2025 so there is no rush to upgrade.
I don't use PSP 2022, but I've upgraded 2 units so far -- both running PSP 2018 on Windows 11 beautifully.
PSP 2022 not working with Win11
Linda Lou
- processor: Intel i7vPro10th Gen
- Hard_Drive_Capacity: 1024 GB
- Monitor/Display Make & Model: ThinkPad Extreme Gen3
- Corel programs: PaintShop Pro 7, 8.1, 2018, 2023
Re: PSP 2022 not working with Win11
Do you still have a WI Preview version? If so, I suggest that you remove that and upgrade.
Did you run the Windows 11 PC Health Check to make sure your device is compatible?
I had to run the cleanup tool a few times but it finally started working. Yes, I'm running Insider Previews - still - but PSP 2022 is now working as it should (after the uninstall and several runs of the cleanup tool then a fresh install).
FWIW, I had to do the same with VSP 2021 - uninstall and run its clean-up tool and then do a fresh install.
Golden_Girl55
- motherboard: Asus Motherboard
- processor: 11th Gen Intel Core i7 11700KF 3GHz
- Video Card: NVIDIA GeForce RTX 3070 Ti
- sound_card: unknown
- Hard_Drive_Capacity: VANCOUVER
- Monitor/Display Make & Model: lg 50 inch
- Corel programs: psp 2022
My new computer came with Windows 11 and I have psp 2022 and it is working just fine. Have a great day!
