VS 2021 Ultimate install
theavy
motherboard: Dell 0CNDTP A00
processor: Intel Core i7-9750H
Video Card: NVIDIA GeForce RTX 2060 6GB
sound_card: NVIDIA Virtual Audio Device Wave Extensible WDM
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Generic PnP Monitor (17.1"vis)
Corel programs: PSP X9 thru 2022 - VS 2020, 2021, 2023
Post by theavy »
I just purchased the 2021 Ultimate (download version) and was a bit surprised that when I ran the installer, I wasn't given the option to specify where I wanted VS installed. Is that standard procedure now? I've always had that ability in the past.
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Re: VS 2021 Ultimate install
Post by Davidk »
It is there. Did you skip the custom install choice in the installer? you won't be offered an option if that radio button isn't active. You also have to choose the location you want (buttons with 3 dots at the end of the path/folder lines, pre-filled with the default location, noting that if you have prior versions from 2019 installed the share page location (the installer calls it content 2) is greyed out and not changeable.
Beyond that, the current version (help/about) is 24.1.0.299
If you - like me - run on custom installs not in the default C drive, and you've been careful about it, then my best suggestion is to uninstall, cleanup, then re-install with a lot of care in the opening pages of the installer: if you choose custom and don't specify a location, the default is where it will be.
Keep in mind the 30 day limit after purchase - if CVS2021 isn't doing what you expect then you still have the refund option, up to 30 days.
theavy
Post by theavy »
Thanks for the reply David. I was looking for a custom choice, but don't recall seeing it. I'll go with the uninstall and cleanup, and give it another try.
Thanks!
Tom
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Post by tletter »
theavy wrote: I wasn't given the option to specify where I wanted VS installed.
The options are there (see fol image). Try a custom installation.
tletter
theavy
Post by theavy »
Yep... I found it on the second go-round.
Thanks for the pointers!
Tom
