Contrast layer under lettering - some tips?
edwinn
- motherboard: Intel
- processor: Intel Core i7 - 8 core
- ram: 16 GB
- Video Card: Intel
- sound_card: Integrated
- Hard_Drive_Capacity: 500GB 4TB
- Monitor/Display Make & Model: Samsung 2494 - 1920x1080
- Corel programs: PSP X4
I'm back after a long time away, but never stopped using PSP X4.
Have been putting labels on Maps with yellow lettering, however due to image contrast, they often get `lost´ in the background. So there's a need to apply a contrast `patch´ for each label on a layer beneath. It works pretty well but just a bit sloppy.
Have put a raster layer under the vector lettering layer, then spray paint med-dark green patches with Airbrush tool under the yellow labels, settings Hard 30 and Opac 40.
The problem with that is: it's difficult to drag the spray tool L-R without going crooked. IOW it would be best to have a perfectly horizontal contrast patch under the labels.
Please comment. Thx
Please comment. Thx
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: Contrast layer under lettering - some tips?
Place your new blank raster layer under the vector lettering layer then use the Rectangle selection tool to create a rectangular selection of the size you need on that raster layer. Then uses the Flood Fill tool and click with it in the rectangle to fill it with your contrast color of choice. You can then adjust the opacity to taste in the layers palette.
JoeB
Using PSP 2019 64bit
JoeB
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Click once at the beginning of the text.
Press the shift key down (and maintain) and click on the end of the text.
A straight line will be drawn between the two clicks.
edwinn
- ram: 16 GB
- Video Card: Intel
That worked really well. I was trying to drag the brush while holding Shift key down. Thing is, was drawing straight lines for years by clicking, shift key, clinking other end.
-Ed
edwinn
- ram: 16 GB
- Video Card: Intel
Could also feather the selection before flood filling? Yeah that will take some experimenting! ThxJoeB wrote: ↑Fri Sep 10, 2021 5:13 pm Place your new blank raster layer under the vector lettering layer then use the Rectangle selection tool to create a rectangular selection of the size you need on that raster layer. Then uses the Flood Fill tool and click with it in the rectangle to fill it with your contrast color of choice. You can then adjust the opacity to taste in the layers palette.
JoeB
- ram: 8 GB
Yes, you could certainly experiment with feathering the selection.
JoeB
JoeB
ConalO
- motherboard: Not Available
- processor: Intel Core i7 1165G7
- Video Card: NVIDIA GeForce MX330
- Hard_Drive_Capacity: 1TB
- Corel programs: PSP 2019 Ult; PSP 2021 Ult;
Have you ever considered using layer styles for contrast instead of adding a layer under your text layer? Outer glow seems to work well for contrast and you can add to all text selections that are on a layer in one application. A sample is attached for reference.edwinn wrote: ↑Fri Sep 10, 2021 4:42 pm I'm back after a long time away, but never stopped using PSP X4.
Have put a raster layer under the vector lettering layer, then spray paint med-dark green under the yellow labels with airbrush, settings Hard 30 and Opac 40.
Please comment. Thx
- Attachments
- Glow.jpg (7.34 KiB) Viewed 1431 times
edwinn
- ram: 16 GB
- Video Card: Intel
Just tried it, and can adjust opacity on the med-dark green glow, but it lowers the opacity of yellow letters the same amount. What am I missing?
- ram: 6 GB
- Corel programs: PSP: 8-2023
How are you lowering the opacity of the glow? Humor me on this one, there are three areas of opacity. There is the Opacity of the entire layer, found on the Layer Palette and the General tab of the layer properties. That one will lower the opacity of the layer and the layer style. THere is the Layer Style called "Layer" which as an Opacity slider. This one will only affect Layer data itself leaving the glow alone. And then there is the Opacity slider on the Outer Glow layer style that one should only affect the outer glow itself, not the text.
edwinn
- ram: 16 GB
- Video Card: Intel
That makes perfect sense, I was adjusting the layer opacity, the first one tried. Need to find the other two settings.LeviFiction wrote: ↑Fri Sep 10, 2021 7:24 pm How are you lowering the opacity of the glow? Humor me on this one, there are three areas of opacity. There is the Opacity of the entire layer, found on the Layer Palette and the General tab of the layer properties. That one will lower the opacity of the layer and the layer style. THere is the Layer Style called "Layer" which as an Opacity slider. This one will only affect Layer data itself leaving the glow alone. And then there is the Opacity slider on the Outer Glow layer style that one should only affect the outer glow itself, not the text.
All three suggestions are very good, just a question of which one fits the subject matter best.
-Ed
Jean-Luc
Could you post an example here?
edwinn
- ram: 16 GB
- Video Card: Intel
You can see the `sprayed on´ contrast patches with Airbrush tool (H:40, O:30) are not uniformly horizontal in the example. It's easy to ERASE a contrast patch, on what I named the `shaders´ layer and repaint it. They doesn't have to be perfect, but should at least be absolutely horizontal. Click example to view full scale and sharp.
edwinn
- ram: 16 GB
- Video Card: Intel
Still a bit disoriented with drawing or painting a patch horizontally. The confusion was in drawing a vector `line´ with the Pen tool (V) where pressing the [Shift] key snaps the line to any 90° or 45° direction. That's what I attempted with the Airbrush, but a brush stroke in NOT a vector line. The work-around is to view the Y-coord in the status bar readout at beginning of the patch (first click), then move brush to the far END of the patch (end click), positioning it with the Y-coord again to form a horizontal paint stroke (same Y-coord at beginning and end).
edwinn
- ram: 16 GB
- Video Card: Intel
BTW, am using the Airbrush tool for patches, not Paint or spray paint brush.
edwinn
- ram: 16 GB
- Video Card: Intel
Attached is one of the early `shader´ layers (just made that word up) on a raster layer under the vector `lettering´ layer. Started doing this in the last day or so, and that's why its crude. It would be ok for some uses like marking GE Sat maps, but for other projects, flooded selections would be best, like the user described above.
These patches would be ok if painted absolutely horizontal. Notice some are painted under each `line´ of lettering, while others are under three or four line labels.
