PaintShop Pro 2022 cannot open WebP
Zeitreisender
Corel programs: PSP 2022 x64
Post by Zeitreisender »
I tried opening WebP files in PSP 2022. Unfortunately that does not work. Is the problem known?
In paint.net I can open, edit and save this format without any problems.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: PaintShop Pro 2022 cannot open WebP
Post by LeviFiction »
Webp images are supported for both reading and writing according to PSP's file format support page in their help documents: https://help.corel.com/paintshop-pro/v2 ... rmats.html
I opened all of the images from here: https://developers.google.com/speed/webp/gallery1
And they worked just fine.
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
Zeitreisender wrote: Wed Sep 01, 2021 2:10 pm I tried opening WebP files in PSP 2022. Unfortunately that does not work. Is the problem known?
Try if XnView recognize - can view your's WebP.
Zeitreisender
Thanks LeviFiction & Radim!
I found the following:
1. WebP files in "Lossless" and "Lossi" (with Alpha) format will not be opened in PSP 2022. (see: https://developers.google.com/speed/webp/gallery2)
2. If I save images with an alpha channel (e.g. PNG files in PSP 2022 as WebP, the alpha channel (transparency) in the image is automatically removed (as well as with JPG files).
3. I can only open WebP images without an alpha channel in PSP 2022 and save them again in exactly the same way.
This is how it works better: With paint.net I can open all WebP formats (Lossless and Lossi), edit them and save them again with the alpha channel. Paint.net also opens a settings dialog box before saving a WebP file. Working with all WebP files is very convenient here.
I hope that Corel will provide further options for the WebP format later, as it is already available in paint.net.
ksaldutti
processor: Intel 7820HK
ram: 32GB
Video Card: Nvidia GTX 1080
sound_card: Realtech
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Viewsonic 2780 4-K
Corel programs: PSP Ultimate X6 X7 X9 2018 WinZip 18.5
Post by ksaldutti »
If PSP cannot open WEBP files the just say so and stop beating around the bush here. It is apparent that very few WEBP file will open and many be saved as jpg or whatever format you wish. So why is this a problem? This is a frequent complaint and no fix! Having to open them in another application and then hopefully being able to convert them before saving them to be used in PSP is just stupid ridiculous. There is obviously a situation that most WEBP file cannot be opened in any version of PSP with the usual error message. Frankly I don’t care why, I just want if corrected. This is supposed to be a professional image editing software application by a company such as Corel. Get it done!
sheng-si
motherboard: Hp motherb
processor: amd
ram: 32 Gb
Hard_Drive_Capacity: 1 tb
Monitor/Display Make & Model: ASUS VG24VQR
Corel programs: paintshop pro Videostudio 2022
Post by sheng-si »
Is there a program maybe online to convert webp files in png jpg c.a. ?
Because it is a really new extension/format for web pages.
Admin FB Paintshop Pro NLD for dutch users.
ram: 6 GB
Yes, one can use the decide and encode command line tools from Google to both convert a webp into a pmg and then back again after you're done with your edits.
https://developers.google.com/speed/webp/download
Lies54
motherboard: Lenovo
processor: Intel Core i5 2400
ram: 4GB
sound_card: High Definition Audio-apparaat
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Acer
Corel programs: x9, 2018, 2019, 2020, 2021
Post by Lies54 »
https://ezgif.com/webp-to-png i used this for the WEBP converter
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
FastStone Image Viewer is free, and it will convert webp to png, including transparency, for PSP 2022, with a "*" note: * "Note: HEIC and WEBP are supported by Windows Imaging Component (WIC) codecs on Windows 10 / 11"
However, it will not convert back to webp.
https://www.faststone.org/FSViewerDetail.htm
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Forriner wrote: Mon Aug 15, 2022 8:08 pm FastStone Image Viewer is free, and it will convert webp to png, including transparency, for PSP 2022, with a "*" note: * "Note: HEIC and WEBP are supported by Windows Imaging Component (WIC) codecs on Windows 10 / 11"
About the Note: Does that mean that FastStone will only convert all Webp formats to PNG if a person has Windows 10 or 11 because, for example, it actually needs the WIC codecs in those systems to do so?
JoeB
Using PSP 2019 64bit
Forriner
ram: 16 GB
Post by Forriner »
JoeB wrote: Mon Aug 15, 2022 9:48 pm
I do not think so but I do not know. WIC codex has been around for a long time in Windows, but has it been updated for all versions? The change log on the FastStone page says for Version 7.1 (May 28, 2019), "Supports HEIC and WEBP formats on Windows 10".
The install file FSViewerSetup76.exe is 6.794 MB. Setup is reasonably fast, so it might be worthwhile just to install and try it. Before trying, it might be a good idea to turn off "Use Thumbnail Database" in Settings (F12), Thumbnail tab.
JoeB
ram: 8 GB
Post by JoeB »
Thanks for the info! I'll give it a try.
JoeB
ram: 6 GB
Just finished some scripts that will let you open and save WebP formats including those with Alpha Transparency - https://forum.corel.com/viewtopic.php?p=395066#p395066
While not perfect, what's nice about this option is you can do everything from within PSP. No need to go to an external program to convert them for you.
JoeB
ram: 8 GB
Post by JoeB »
LeviFiction wrote: Wed Aug 17, 2022 2:29 am Just finished some scripts that will let you open and save WebP formats including those with Alpha Transparency - https://forum.corel.com/viewtopic.php?p=395066#p395066
I will definitely be grabbing this! :-)
JoeB
