After the apparently successful installation, AfterShot is not among the applications.
I start it manually in the terminal:
Code: Select all
'/opt/AfterShot3(64-bit)/bin/AfterShot'
inotify_add_watch(/home/michael/.config/ibus/bus/39c8ba3acfd04bc8843e9397b3e0e746-unix-0) failed: (No space left on device)
I have SSE2
Loading plugins
Loading camera modules from "/supportfiles/cameras"
Loading camera modules from "/home/michael/.AfterShot Pro 3/Cameras (64-bit)"
Bibble program arguments ("/opt/AfterShot3(64-bit)/bin/AfterShot")
libpng warning: iCCP: known incorrect sRGB profile
AfterShot vers.: 3.7.0.446
Built on: "Di. Jan. 19 2021"
Language: de
App Path: /opt/AfterShot3(64-bit)/bin/AfterShot
System Home: /supportfiles
User Home: /home/michael/.AfterShot Pro 3
Prefs Home: /home/michael/.config/Corel/AfterShot Pro v3.conf
Platform: Linux
Issue: "Ubuntu 20.04.3 LTS \n \l"
Kernel: "Linux version 5.11.0-27-generic (buildd@lcy01-amd64-019) (gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #29~20.04.1-Ubuntu SMP Wed Aug 11 15:58:17 UTC 2021"
Build Mode: Release
Product Name: "AfterShot Pro 3"
Trial Version
Initializing
Cpu Manager init: 4
**** Making CLManager
Got 1 platforms
OpenCL is disabled in low mem mode
platform 0x7f8ffbe8de70 "Advanced Micro Devices, Inc." OpenCL Version: "OpenCL 2.1 AMD-APP (3224.4)"
device: 0x38e90c0 "Ellesmere"
****** Device "Ellesmere" enabled
LDS size 32768
Compute units: 32
Freqency: 1268
Max work items: 256
Max work item sizes: 1024 1024 1024
Device OpenCL Version: OpenCL 1.2 AMD-APP (3224.4)
Device OpenCL C Version: OpenCL C 1.2
Device OpenCL Extensions: cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_image2d_from_buffer cl_khr_spir cl_khr_gl_event
Device Memory: true
Zero Copy: false
SVM: false
LDS size 32768
Compute units: 32
Freqency: 1268
Max work items: 256
Device Memory: true
Zero Copy: false
SVM: false
tileSize: 512
"MemTotal: 16253464 kB"
Memory: 3
Asset: 2147483647 purge
Heavy Asset: 2147483647 purge
NoiseEngine: 150 purge
NoiseEngine: 75 cache (50 min)
Histogram: 24 purge
Histogram: 12 cache (12 min)
PluginData: 9 purge
PluginData: 9 cache (8 min)
ImageMaster: 600 purge
ImageMaster: 300 cache (50 min)
NContainer: 2147483647 purge
Path: 2147483647 purge
Path: 2147483647 cache (2147483647 min)
RawData: 25165821 purge
UncompressedRawData: 9 purge
UncompressedRawData: 9 cache (8 min)
Version: 600 purge
Version: 300 cache (50 min)
PerfectlyClear: 6 purge
PerfectlyClear: 4 cache (4 min)
TileStack: 24 purge
TileStack: 12 cache (12 min)
StackTile: 3000 purge
Created 626 buffers of 857472
FALLBACK to 1252 tiles
BImageTile: 1800 purge
BTiledImage: 2147483647 purge
RegionImageTile: 3000 purge
Allocate Asset manager
Option group - "" - already contains an option with name - "TIFFTAG_AFMODE"
Option was not registered.
Option group - "" - already contains an option with name - "TIFFTAG_FLASHMODE"
Globals: systemhome /supportfiles
Globals: userhome /home/michael/.AfterShot Pro 3
==================== Plugins =====================
Failed to open rename formats file: "/home/michael/.AfterShot Pro 3/locale/de/rename.txt"
Couldn't open lens table file: /supportfiles/Profiles/LensProfiles/profile_canonlenstable.txt
SettingsWindow::addTabs() - ui file missing: "/supportfiles/tools/BasicTools.ui"
SettingsWindow::addTabs() - ui file missing: "/supportfiles/tools/Histogram.ui"
SettingsWindow::addTabs() - ui file missing: "/supportfiles/tools/Advanced/Exposure.ui"
SettingsWindow::addTabs() - ui file missing: "/supportfiles/tools/Watermark.ui"
Speicherzugriffsfehler
Thanks in advance
Many greetings
Mierscheid
