Stupid Noob Question - how do I lock and cut multiple tracks?
christopheran
processor: Intel Core i7-4710MQ
ram: 24gb
Hard_Drive_Capacity: 250gb
Corel programs: VideoStudio Ultimate 2021
Post by christopheran »
I figure this must be such an obvious thing that then don't even cover it in any of the how-to videos (none that I found, at least).
I need to edit out a section of my video across all tracks. If I just edit a clip, then I'm going to have to rearrange all my clips on each track to get the timing lined back up.
How do I lock all the tracks together and then make a cut that affects all tracks?
Thanks,
Chris
Re: Stupid Noob Question - how do I lock and cut multiple tracks?
Look up the Help or User Guide for Ripple Editing. Essentially, though, it is enabled for each track to the far left of each track. It looks like a tiny chain link -- see attached image. Each one has to be enabled for that track to be affected by editing. So if you want to make a cut in all the tracks at the same place, then make sure Ripple Editing is enabled for all the tracks.
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
christopheran wrote:Hard_Drive_Capacity: St Augusti
You should update your profile to indicate the version of VS that you're using and provide meaningful info.
christopheran wrote: How do I lock all the tracks together and then make a cut that affects all tracks?
Enabled ripple editing, and position the scrubber where you want to cut and then use the split cut feature.
tletter
christopheran
ram: 24gb
Thank you Ken, tletter,
Adding some additional info to profile, thank you for that tip.
Enabled ripple editing - would never have thought to look up 'ripple' :)
Still having trouble though. I should be able to set the tracks into ripple mode, then split out a section and delete, and the deletion applies to the other tracks as well - or am I misunderstanding something?
Here's a video screenshot of what I am doing:
https://screencast-o-matic.com/watch/crj0YkVj8xW
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
you didn't mark "ripple" on the other tracks so how they will follow?
Panasonic X900m, VXF1
click image for larger view
christopheran
ram: 24gb
Ohhhh - ha :)
Okay, when I clicked that one, they all lit up, so I thought it had selected all. Ugh, now I've got it.
Thanks you, 'preciate the patience!
Chris
