I have run into an problem in attempting to burn/create ISO for my first BD-R with VS Ultimate 2021.
When the burning process gets to the Video/Audio Multiplexing, the process stops at 2% progress for the multiplexing. It did this first when I attempted a burn to disc, so I restarted the application and burned to an ISO instead. Same non-responsive point at 2% with the elapse clock stopping.
Project Settings
Code: Select all
MPEG Transport-Stream Files
24 bits, 720 x 480, 29.97 fps
Upper Field First
(HDMV-NTSC), 16:9
H.264 Video
Video data rate: Variable (Max. 4000 kbps)
Audio data rate: 256 kbps
Dolby Digital Audio, 48 KHz, 2/0(L,R)MPEG Properties for File Conversion
Code: Select all
Checked Do Not Convert Complaint MPEG files
MPEG files
Upper Field First
(HDMV-NTSC), 16:9
H.264 Video
Video data rate: 5700 kbps
Dolby Digital Audio, 48 KHz, 2/0(L,R)Code: Select all
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/iso2/avc1/mp41)
File size : 4.21 GiB
Duration : 2 h 3 min
Overall bit rate : 4 887 kb/s
Encoded date : UTC 2021-08-17 06:51:33
Tagged date : UTC 2021-08-17 06:51:33
Writing application : HandBrake 1.4.1 2021081500
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 4 623 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.446
Stream size : 3.99 GiB (95%)
Writing library : x264 core 163 r3059 b684ebe0
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=15 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 2 h 3 min
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 32.0 kHz
Frame rate : 31.250 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 226 MiB (5%)
Source stream size : 226 MiB (5%)
Title : Stereo
Default : Yes
Alternate group : 1
mdhd_Duration : 7406144
