Am I the only one to see this problem in PSP 2022?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
In PSP 2022, I place a text in a selection.
Centering the text produces an overlap (see attached).
Do you see the same problem?
PS: Perhaps because I have a French OS?
Re: Am I the only one to see this problem in PSP 2022?
In my case in PSP 2022, all the alignment tools work correctly. You continue to see all of the text clearly, though aligned to what was chosen (left, right, centre).
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Is it different if you use a vector frame instead of a selection frame?
Jean-Luc
Post by Jean-Luc »
LeviFiction wrote: Wed Aug 18, 2021 12:13 am Is it different if you use a vector frame instead of a selection frame?
It happens only with the text inside a selection made by the Selection Tool.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
Yes, I can confirm but it only happens on Align Center; not with Align Right or Align Left.
Jean-Luc
Post by Jean-Luc »
Kathy_9 wrote: Wed Aug 18, 2021 2:43 pm Yes, I can confirm but it only happens on Align Center; not with Align Right or Align Left.
Yes, and Force Justify and Justify are not working.
Jean-Luc
Post by Jean-Luc »
Hi, Kathy,
could you confirm on CenterCode (see 0843)?
Kathy_9
Post by Kathy_9 »
Yes, done.
splash3313
Hard_Drive_Capacity: 1tb
Post by splash3313 »
Have you deleted the txt and reentered it and does that work?
Do the formating first and then see if that work.
if others are not getting or seeing this then it could be a display setting or another windows setting.
Jean-Luc
Post by Jean-Luc »
If you don't see the defect on your system, do my exact steps (text in a selection, not a vector form) and try with different font sizes and do Center, Align, Justify, etc. I am sure you will see the problem.
PS : for example, I see the defect when the text is selected (greyed) and I apply an Arial font, centered, with 18 pixels size or 96 pixels size.
Zantara
processor: i5-2100 3 10 Ghz
ram: 12Gb DDR4
Video Card: Intel UHD graphics 620
Hard_Drive_Capacity: 256SSD 1TB
Corel programs: From PSPX2 to PSP2022
Post by Zantara »
In Dutch version of PSP 2022
Jean-Luc
Post by Jean-Luc »
Zantara wrote: Sat Aug 21, 2021 10:56 am In Dutch version of PSP 2022
Try with Arial and different font sizes in pixels.
With Bookman Old Style, try 20 pixels or 22 Points.
PS : I'm creating my file at 300 PPI. Different PPI produces different behavior.
