Rightclick dragging the selection is not possible.
I have PaintShop Pro 2020. Recently a problem persists. In the selections tool, I could move the selection by right click dragging in the past. Now it is not possible. When I click "Magic Move" option on the tool options palette, "runtime error warning" appears on the screen, stops running and asks me to close the program. Also, recently during opening the program, "The autosave file is not valid or has been damaged" warning appears. When I click OK, the program opens smootly. I will appreciate your help.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Rightclick dragging the selection is not possible.
Try doing a factory reset and clearing the caches.
As an initial reset, hold down the Shift key when you click on the desktop PSP icon to open it. You will be asked if you want to reset. Make sure you first save any Customized workspaces as they will be lost in the reset.
If you want to look at other ways of resetting, see https://forum.corel.com/viewtopic.php?f=56&t=67616
Thank you. The second choice in the link has worked.Ken Berry wrote: ↑Sat Aug 14, 2021 5:25 am As an initial reset, hold down the Shift key when you click on the desktop PSP icon to open it. You will be asked if you want to reset. Make sure you first save any Customized workspaces as they will be lost in the reset.
Thank you. Shift+ double left clicks has worked.
