[Sticky] - What Do You Like/Not Like About PSP2022?
cindyks
motherboard: HP Envy Desktop 795-0xxx
processor: Intel Core i7-8700
Video Card: NVIDIA GeForce GTX 1060 3GB
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Element TV/Monitor
Corel programs: PSP 2022
Re: [Sticky] - What Do You Like/Not Like About PSP2022?
Post by cindyks »
The resize is extremely slow in some cases. I've noticed it when resizing images to make them larger.
I have a good computer, but the resizing strains the processor and slows any other open windows down.
Sometimes it takes over 30 seconds to resize.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
If you don't need AI-powered to resize you may switch to Smart Size.
divine_si
ram: 4gb
Hard_Drive_Capacity: 120 TB
Corel programs: PSP9 / x9 / x10 Studio 10 / 19 /20
Post by divine_si »
What I don't like:
1) it is VERY slow to load compare to previous versions;
2) the tutorial tiles are ANNOY in edit mode. Sure they go away, but there should be a way to turn them off;
3) I hate the every time I load it up I have to turn off the "tabbed documents". I wish it would remember that setting
4), probably the thing that I hate the most is that the "Photography" workspace can only be used in fill screen mode. WHY??
I haven't found anything in this version that I like more then previous versions. Hopefully that will change with continued use.
cfosp1
motherboard: MPG X570 GAMING EDGE
processor: AMD Ryzen 7 2700X
ram: 64 GB
Video Card: Radeon RX 580 Series
Hard_Drive_Capacity: 4 tB
Monitor/Display Make & Model: Samsung SyncMaster 225sw
Corel programs: PSP '22; VideoStudio '21; AfterShot 3 pr
Post by cfosp1 »
I have been using PSP for many years. Generally very satisfy with UI, capabilities, etc. Like occasionally happens, this time again issues with the program that should not be there IMHO. This time, it's the vanishing standard tool bar and missing keyboard shortcuts. Resetting PSP 2022 to the defaults takes care of it until you start the program the next time.
Also, a request to update the just installed program resulted in multiple abords. It would help that if an update turns out to be troublesome to get a message from Corel about this.
I like the AI background replace feature but it is not flexible enough. It should be possible to a number of things with the selection or deselection, not only replace, but also adjustment edits or effects.
I don't understand the concept of the simplified UI, too limited. But it was easy enough to get the full UI activated.
divine_si
ram: 4gb
Post by divine_si »
I don't like how slow it is. It's slow everywhere. I just tried to do my first "Batch Process" on a bunch of photos with some custom scripts that I use. On X9 it takes about 5 minutes per photo, so my 51 photos will usually take about 2.5-2.75 hours depending on what else I'm doing on the computer at the time. Using 2022 and barely running anything else it took almost 8 hours for it to process that batch of photos. Looks like X9 is going to be my go to for those occasions at a minimum. The more I'm using 2022, the more I appreciate x9.
Lijpeijp
motherboard: Dat weet ik niet
processor: Intelcore i7
ram: 6 GB
Video Card: Ati mobility radeon HD 5650 1GB
sound_card: Dat weet ik niet
Hard_Drive_Capacity: 1000 GB
Monitor/Display Make & Model: Acer
Corel programs: Paintshop 4 Paintshop 2018 AfterShot p
Post by Lijpeijp »
Mist001 wrote: Thu Sep 02, 2021 10:31 pm I currently use PSP 2021 Ultimate and tried the trial of 2022 specifically for the AI background removal feature. It is shockingly, laughingly poor. I can't really believe that they're using that feature as a selling point. It has to be tried to be disbelieved!
The background remover is for that I have updated PaintShop but if that is Ai then I don't think it works well.
And otherwise not much has changed and I will not use those simple and slow Workspaces, but only use Complete and then nothing has changed.
Updated for nothing, I'm now going to wait for Luminar Neo to see if AI will work better and faster there.
ValMcCager
Post by ValMcCager »
After upgrading to PSP 2022, I decided to go ahead and take it up to Ultimate. The install says PSP 2022 is already installed and quits. Tech has been working on it, but so far, no luck.
Can we take it you have tried uninstalling the first version then -- perhaps after rebooting -- installing the Ultimate version?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Also the cleanup tool - https://forum.corel.com/viewtopic.php?f=56&t=52337
I mean, technically the only thing PSP Ultimate has in program that Pro doesn't is the Sea To Sky workspace and use of the pro or ultimate splash screen on startup. Everything else is just an extra.
ValMcCager wrote: Wed Dec 01, 2021 6:50 pm The install says PSP 2022 is already installed and quits.
Normally, when you run the installer again and already have the program installed, you should get a message offering to modify, repair or uninstall the existing installation. Do you recall exactly what your message said? I am wondering if it said the program was already installed but went to offer one of these three alternatives...
pierre
motherboard: MSI A320M PRO-VD PLUS AM4 DDR4
processor: AMD Ryzen 5 1500X
Video Card: Asus GeForce GTX1060 3GB PH-GTX1060-3G J2C0Y222600
Hard_Drive_Capacity: 480GB
Monitor/Display Make & Model: Samsung SyncMaster 941BW
Corel programs: PaintShop Pro 2022 Ultimate
Post by pierre »
I'm unable to install CreativeCollection. No CreativeCollection folder appears in the PaintSop Pro 2022 folder. No CreastiveCollection offered in the PaintShp Pro Welcome menu. Zero support from Support Engineer aka Diogo Barbosa despite several requests. Seem that If your problem cannot be solved right away and effortlessly your'e left to your own devices. Will I be banned for complaining?
ValMcCager
Ken Berry wrote: Wed Dec 01, 2021 11:41 pm
No options, just a Quit box.
Jonasbrothers00
motherboard: amdboard
processor: amd
ram: 16gb
Video Card: amd3gb
sound_card: mediatech
Hard_Drive_Capacity: Lahore
Monitor/Display Make & Model: hp
Corel programs: motherboards
Post by Jonasbrothers00 »
I currently use PSP 2021 Ultimate and tried the trial of 2022 specifically for the AI background removal featureIt has to be tried to be disbelieved!!!
But I want to try this at least!!!!.
BluZ2055
processor: Intel Core i7-7700
Video Card: Nvidia GeForce GTX 1070
Hard_Drive_Capacity: 2.25 TB
Monitor/Display Make & Model: Samsung FreeSync
Corel programs: PSP X8 64 bit, Fast Flick
Post by BluZ2055 »
Is this still in BETA? It doesn't work very well. Well, some of it works well, and some of it doesn't.
What I like. I love the familiar interface and work space so I can go right back to what I was doing. The new downloads look exciting, if I could get them to work.
I could not download Painter Essentials or Particle Shop. It seems they cannot find an online installer.
Photo Mirage will not close, Nothing functions but the Welcome screen. In order to close it I must go to the Task manager.
If I go to "Brushes" and look in File Locations, it tells me where the brush files are supposed to be, but when I go to that location, the folder is empty. The program lists three file locations but two of the locations don't even exist. And why did they go to my OneDrive? I have looked for the BP Organic, Pointillism, Chaos, etc. brushes and cannot find them. Addendum: I found them. They were not where they were supposed to be, obviously.
Needless to say, I am a little frustrated with the extras, but the main program basically works.
BluZ
Herodios
System_Drive: N/A
Post by Herodios »
Jean-Luc wrote: Thu Sep 02, 2021 11:14 am
rweavers wrote: Thu Sep 02, 2021 6:12 am Can you get rid of the tutorial tiles in Edit mode. I find them quite distracting.
They disappear when an image is placed in the workspace.
Seriously, that's your answer? That is not good enough. Not even close. I don't want them there at all.
I found this Q and A via google and registered with this board *specifically* to get the answer to this question.
If there's truly no way for a user to scrub this graffiti off the workspace, I will revert to the previous version.
Locked
