rotate photos
newbw 64
- Corel programs: VS2010, Psp ultimate 2021
rotate photos
Looking for a corel program software I hav used before. It makes it possible to rotate photos in all axes1.
- fs999
- System_Drive: Z
- motherboard: Intel
- processor: i7 860
- ram: 32GB
- Video Card: NVIDIA GeForce GTX 730
- sound_card: Samsung HDMI
- Hard_Drive_Capacity: 28 TB
- Monitor/Display Make & Model: Philips 24P4 & Samsung UE46M6050
- Corel programs: PaintShop 2023 Ultimate
Re: rotate photos
In all degrees you mean ?
Yes. Use the command Image - Free Rotate...
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: rotate photos
Free Rotate ( or using the Pick tool) only rotates in 2 axies (X and Y). If they are referring to all 3 axies (X, Y, and Z) then that's a plugin as PSP doesn't support 3D. The KPT filters (32-bit only) have a Projection plugin that allows rotating a plane in 3D. But I don't know enough about Corel products outside of PSP that might allow the same.
newbe64
- processor: AMD Athlon xp 1500
- ram: 2MB
- Hard_Drive_Capacity: 52GB
Re: rotate photos
Thank You, The KPT filters was what I'm looking for!! Where can they be downloaded? Which is the latest Psp-version they can be installed in?
- ram: 6 GB
Re: rotate photos
It requires the 32-bit version of PSP be installed to use, but should work with all recent versions. And you get it from the store or do more section of the PSP home screen in app. It's a free download inside PSP.
newbe64
- ram: 2MB
Re: rotate photos
Very greatful for Your help, thank You, You solved my problem !
