3d title editor causing videostudio to shut down.
captain scarlet
operating_system: Windows 7 Starter
System_Drive: B
Post by captain scarlet »
I am editing a video with Video Studio Ultimate 2019 and everything is fine until I try to add text via the 3d title editor when I get a pop up window stating " Corel videostudio has stopped working A problem caused the program to stop working correctly. Windows will close the program and notify you of a solution is available. "
Videostudio then shuts down. This only happen on 3d title editor. I have tried another video that I have added text in the past and its the same result. I have uninstalled and then reinstalled videostudio but it is still closing down.
Any idea's.
Thank you.
Re: 3d title editor causing videostudio to shut down.
captain scarlet
and welcome to the forums
sorry you are having problems with 3DTE
I have just tried using with 2019, no issues there seems to work ok
Can you try using the 3DTE using the library samples
As a test Start a new project
Drag SP-V01.mp4 to the timeline, you should see a message to match the properties, yes to that
Now try using 3DTE
If that works ok then I would suspect your Project Properties and or your of video being used.
Otherwise I can only suggest you try re-installing again but this time use the Cleanup Tool to remove the program,
Find the cleanup tool here
https://forum.corel.com/viewtopic.php?f=1&t=59847
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
captain scarlet wrote: Videostudio then shuts down. This only happen on 3d title editor.
3D Title Editor in VS2019 has serious issues - see https://forum.corel.com/search.php?keyw ... sf=msgonly
tletter
tletter
Following the links in your post takes me to a topic related to VS 2018 not VS 2019
And things do change from version to version, I have to say not always for the better
tletter
Post by tletter »
lata wrote: ... the links in your post takes me to a topic related to VS 2018 not VS 2019
The 3D Title Editor in VS2019 is unchanged from that in VS2018, hence the issues remain unchanged.
tletter
captain scarlet
System_Drive: B
lata wrote: Sat Jul 31, 2021 9:05 am
Now try using 3DTE
Thank you for your reply.
I tried the above suggestions but still no luck. I tried using the 3DTE without a video being downloaded but again as soon as I click on the 3DTE tab it crashes.
Video Studio 2019 has 10 3D sample titles
Access these from the “T” title library, select the down arrow next to Title for 3D Title
Drag one of those to the timeline, then double click the clip should open the editor
Does VS still crash.
Couple of things to try
1 / Go to preferences (F6) Performance tab and deselect all acceleration options.
2 / Can you try running the VideoStudio_3D_Title_Editor.exe installer to see if that on its own fixes things
From your downloaded installation files here:-
64bit\Ultimate\Setup\RunTime ---- VideoStudio_3D_Title_Editor.exe
It is difficult to know which version we are running as the 3DTE has no About details.
The actual file I see as 30,936kb
Right clicking that file for Preferences – Details tab shows the Product version as 1.0.9.179
At least that is what I see.
captain scarlet
System_Drive: B
lata wrote: Mon Aug 02, 2021 8:08 am Video Studio 2019 has 10 3D sample titles
I tried access via the "T" it still crashed.
I had already tried the " Go to preferences (F6) Performance tab and deselect all acceleration options." No luck.
As for the "VideoStudio_3D_Title_Editor.exe installer" Thats gone over my head, I'm a luddite.
Do you have any other VS programs installed or just 2019?
When you re-installed VideoStudio2019 did you use the cleanup tool to remove the program.
Download from this post
The cleanup tool does a more thorough job.
You can then install VS 2019 hopefully with better results.
captain scarlet
System_Drive: B
lata wrote: Wed Aug 04, 2021 5:01 pm Do you have any other VS programs installed or just 2019?
I have re-installed videostudio 2019 with and without using the clean up tool.
I only have painshop pro x9 ultimate installed as well.
I am going to try installing on my laptop ( when I can find it ) and see if that helps as it is unused and has nothing downloaded on it.
I also suggest you download the 2019 installation files again.
Choosing an empty download folder will give you the latest files.
Just in case they have been updated since your last download
