I would like to use some Borix FX templates, but I have no clue how to edit it. I don't even find the word Boris in the Video Studio help files.
I've done a search on Youtube, and didn't find much there either. I did find https://borisfx.com/videos/?tags=host:C ... ro&search=, but not much indicating Video Studio Boris products. I don't want to spend a bunch of time there if it isn't something I can use to understand it in VS, although I did find something on Title Studio.
Can anyone point me to something to learn Boris Templates?
Boris FX editing how to?
56_kruiser
- motherboard: Lenovo
- ram: 16gb
- Hard_Drive_Capacity: 475GB
- Monitor/Display Make & Model: Lenovo
- Corel programs: Videostudio Ultimate 2022
_________________________________________
VideoStudio ULTIMATE 2022
And versions 2018-2020 before
Re: Boris FX editing how to?
The last version of Video Studio to include Boris Graffiti was VS 2018 (afaik) so you will not find using 2020
If you have X9 still installed you could use that.
You can also copy the appropriate file from X9 to VS2020
C:\Program Files\Corel\Corel VideoStudio X10\vft_plug\Graffiti7.vft
It should then be available in FX library of 2020
Personally I do not know of a tutorial for Boris Graffiti, any that you find on the interned may be for the full pro version.
There is a free Particle Illusion from Boris that you may find useful again will not be the pro version
https://borisfx.com/products/particle-illusion/
56_kruiser
- ram: 16gb
Not sure I follow related to Boris not being in 2020:
I did some more browsing in VS and found that it apapears the stuff pictured above may be edited in the Boris Title system.
56_kruiser
- ram: 16gb
Update...I was able to change text with Title Studio. But I don't see how I can change the attributes of the text
First apologies for any confusion here…..
Video Studio FX library contains Boris FX / Boris Graffiti 7.0
This was no longer provided after VS 2018
The program also provided BCC Title Studio, also accessed via the FX filter library.
To use the above we drag the filter to a clip on the timelines, double click the clip to open the options panel, here we can choose Customise.
In addition to the FX Filters the program provided Instant Projects, best described as good examples of the capabilities of the filters.
These on your program are showing as BorisFX within the IP library, they are from BCC plugin.
I do not have 2020 installed at the moment but will do so, then I should be able give you more info.
56_kruiser
- ram: 16gb
Thanks for the input. I appreciate it.
I have gotten some done with the titler. I was able to modify the text in one of the Boris items I was using. Haven't discovered how to change color/formatting on the text yet. But I'm getting by for the moment.
- RobertOZ
- Hard_Drive_Capacity: 7 TB
This link to tutorials may help you, not necessarily for VS, but the procedure creating titles is still the same
https://borisfx.com/documentation/conti ... io-basics/
