Jammed test on slides
earthcomedy
System_Drive: D
Corel programs: Video Studio X10
Post by earthcomedy »
https://www.dropbox.com/s/0ifso96jsb55r ... t.jpg?dl=0
I have a title slide and there are two text areas. This is one of them. As you can see the text on the bottom is jammed and letters are running into each other. Any idea on how to fix?
I've changed fonts, font size, to no avail.
Thanks.
Re: Jammed test on slides
Sorry but you can't just insert an image with your post. You have to be in the full Editor and click on the Attachment button below the space for your post, then browse to where the image is stored.
earthcomedy
System_Drive: D
ok. I got a wrong title anyway. Let me repost. Tried to delete but you responded so fast!
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
earthcomedy wrote: As you can see the text on the bottom is jammed and letters are running into each other.
Actually looking closely at the text on the top, it's "jammed" too but not as significantly. There appears to be a kerning issue due to a border.
I'd suggest that you post a VSP containing the title shown in your posted jpg, so people can check out the cause.
tletter
As request by “tletter” can you attach your VSP to your post
We can then view the text / titles, we cannot see your image or video clips
You will have to Zip your VSP to attach to the post, or rename to use txt as its extension.
The smaller text looks as though it has been rotated, did you apply any animation, or pushed together in some way?
Either way the VSP would help.
tletter
Post by tletter »
earthcomedy wrote: Any idea on how to fix?
As previously mentioned, yours appears to be a kerning issue due to an excessive border. The problem that you showed in your image is reproducible if you set the outer stroke border to a large value, e.g. 77 as opposed to a value such as 10 (see following image).
tletter
earthcomedy
System_Drive: D
Yes, I fixed the issue, it was a border issue!
