4k crashes
john chapple
- motherboard: ASRock B450M Pro4-F AMD Socket AM4 Motherboard
- processor: AMD Ryzen5 3600
- Video Card: intigral
- Hard_Drive_Capacity: 6tb
- Monitor/Display Make & Model: HP w2216
4k crashes
Hi. I have recently purchased a Panasonic X1500E 4k camcorder. Corel video studio 2020 crashes when I try to play or render to MP4 MOV 3840x2160 50fps clips. What am I doing wrong please.
cybernick
- Video Card: GTX 1060
- Hard_Drive_Capacity: 1TB nvme
- Corel programs: Video Studio 2020&2021 Ultimate
Re: 4k crashes
Try installing k-lite.
john chapple
Re: 4k crashes
No joy with that!
Re: 4k crashes
On the Share page, have you enabled Hardware encode acceleration? What is it set to, and have you tried unselecting it? VS 2021, by the way, includes AMD there, but not in VS 2020 which you have.
excalibur1814
- motherboard: NUC 13
- processor: i3-1315u
- ram: 32Gb
- Video Card: Intel UHD Graphics for 13th Gen Intel Processors
- sound_card: Onboard
- Hard_Drive_Capacity: 1Tb Samsung 990
- Monitor/Display Make & Model: Samsung 49" 5120 x 1440 Pixels screen
- Corel programs: VideoStudio 2023 & PSP 2021
Re: 4k crashes
Install quicktime?
- Davidk
- ram: 16Gb
- Hard_Drive_Capacity: 6Tb
Re: 4k crashes
First comment: what is the format of your camera recording? when the camera clip is input to the timeline: click on the clip, rt-click and select properties, screenshot that detail and post to this thread. If the program crashes when trying to input the clip that format is likely to be one that VS doesn't like.
To play in edit mode - ensure that smart proxy is enabled, and give the program time to create the proxies - it doesn't happen instantly: when done, a small keyboard-like icon shows in the timeline clip thumbnail.
To render - hardware acceleration has a reputation for issues when selected. So, if it's enabled, try turning it off for the render operation: it will take longer but not likely to cause issues.
john chapple
Re: 4k crashes
can't seem to post a screenshot
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
Re: 4k crashes
Was there an error message? Is your file too big? In any event, you can always post to a filesharing site, e.g. Dropbox.john chapple wrote: can't seem to post a screenshot
tletter
Re: 4k crashes
John
When replying please select “Full Editor & Preview” this is immediately below the Subject text panel
Your view will now expand to show a couple of tabs, Options and Attachments, select Attachments.
Add Files to browse and find your image / screen shot
Your file should show in the Filename panel
Position the cursor at the bottom of the text - then place in line
Re: 4k crashes
John please note ...... I have updated your preferences to allow you to receive post notifications, if you do not wish to use this option we can deselect that, just thought in this case it may be helpful.
john chapple
Re: 4k crashes
file details are
Quick time movie files
3840x2160
36.000 seconds
24bits 3840x2160
total frames 1,800
frame rate 50,000 duration 36 seconds
compression
Attributes 40,000Khz 24 bits stereo
Hope tis helps
3840x2160
36.000 seconds
24bits 3840x2160
total frames 1,800
compression
Hope tis helps
Re: 4k crashes
Thanks for that. You will note that you have your camera set to film using the Quicktime format. That's fine, but you have to be aware that Quicktime is not automatically part of Windows or installed by VideoStudio. So as excalibur suggested above, you need to install it. Apple, which developed Quicktime, has stopped supporting it for Windows but that is because of a problem with the QT player, not the codec itself. So you can still install that manually.
But I notice that your camera can also be set to film using the AVCHD H.264 codec (which is useful if you are thinking of making Blu-Ray discs). It too gives a form of mp4 and is already on your computer
The camera can also be set to film in HEVC H.265 format which is excellent. It is an mp4 format which gives high quality video but with a smaller size. You need to install a tiny app from Microsoft which is easy enough. If you Google it, you will find a way of doing so free of charge, though I think MS only charge $1.50 for it or something roughly similar to that. The only problem with HEVC is that it requires a fairly powerful computer to be able to play and edit it.
So all three formats your camera can use will provide good results. If you decide to continue using Quicktime, then follow these instructions. They were written for an earlier version of VS but still apply. https://forum.corel.com/viewtopic.php?p=382228#p382228
john chapple
Re: 4k crashes
Thanks so much for your help Ken.
Still no luck with VS. It crashes every time I import and try to play a HEVC file. I've paid good money for VS and I'm more than a little fed up with it. Just a note I installed the 'FREE' Davinci Resolve program and it has absolutely no problem playing and editing HEVC. Corel need to wake up!
Re: 4k crashes
Did an installation disc come with the camera? And if so, did you install it? I ask since in the past we found that Panasonic tweaked a format to their own slightly different specifications and earlier versions of VS couldn't handle it. But they usually supplied an accompanying disc which contained their own version of the codec.
That of course doesn't explain the fact that Resolve has no trouble but sometimes other programs can be more 'forgiving' than VS for certain formats. FWIW, on my current computer (see my Profile) I had absolutely no luck trying to play and edit HEVC, despite having installed the HEVC Extension I mentioned. Intel assured me my computer could play it. Indeed, I found that Movie Studio Platinum played it without problem. Anyway, I had to reinstall Windows for a completely unrelated problem, and all of a sudden, VS had no trouble with HEVC.
I am also wondering if you have installed Quicktime Essentials yet, and whether it improved your experience with .mov files from your camera?
john chapple
Re: 4k crashes
Hi Ken. The camera doesn't come with an installation disc. I import the files directly onto my pc through the card reader. I installed quick time as soon as I got the pc with 4k in mind. It's a shame VS doesn't seem to work. I do like it but I don't think I'll be upgrading again. They need to do a fix for VS2020. My hardware can handle it but the software cant and it's so frustrating!
All the very best Ken
Thanks again for all your help
John
John
