Are you ready for 14 Oct. 2025?
irvinborder
System_Drive: D
motherboard: auusi dwee disp
processor: amd
ram: 512
Hard_Drive_Capacity: 120
Monitor/Display Make & Model: vdis
Corel programs: corel
Re: Are you ready for 14 Oct. 2025?
Post by irvinborder »
tletter wrote: Fri Jun 25, 2021 10:36 pm A major shortcoming of the PC Health Check tool is that it simply declares that "This PC can't run Windows 11" without flagging which of the minimum system requirements is unmet. Hopefully MS will upgrade the tool and make it more didactic.
The following steps are necessary to remove requirements error "This PC can't run Windows 11" when attempting to install Windows 11
you can bypass the CPU / TPM Check by adding DWORD to registry in the below mentioned path.
Computer\HKEY_LOCAL_MACHINE\SYSTEM\Setup\MoSetup
Add DWORD with the value name as AllowUpgradesWithUnsupportedTPMOrCPU and Value data as 1.
Download the Windows 11 iso from official website and mount in Virtual Drive using PowerISO or similar application.
Then RUN the windows 11 setup from the virtual Drive and follow the process. you are good to go with windows 11
*Make sure the secure Boot is enabled in BIOS.
