I just imported a pretty long video MPEG-4 clip into VS Pro X9--and hour and a half--and after importing OK, upon playing it, it displayed a small blue whirly icon for awhile, then the audio track
gave off a buzzing sound throughout...
Yet when I imported the clip into an Open Source video editor--Open Shot--the clip payed back just fine, with the audio track without the buzzing.
Very strange!
Weird Audio Upon Importing An MP4 Clip
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: Weird Audio Upon Importing An MP4 Clip
What are the properties of the clip?DayO wrote: I just imported a pretty long video MPEG-4 clip into VS Pro X9
tletter
DayO
- motherboard: HP 18E7
- processor: Intel Core i5 4750 CPU 3 20 GHz
- ram: 32 GB
- Video Card: Intel HD Graphics 4600 1024 MB
- Hard_Drive_Capacity: 3932 GB
- Corel programs: Video Studio Pro X9
Clip Properties:
Video Type: H.264 High Profile Video
Attributes: 24 bits, 450x800
Frame Rate: 29.983 frames/sex.
Data Rate 1004 Kbps
Audio:
MPEG AAC Audio
Total Samples: 116,643, 840 samples
Attributes: 2400 Hz, 16 bit stereo
Bit Rate: 64 Kbps
Clip is 1 hr, 21 minutes in length
Audio is more characterized as scratchy, not buzzing.
Data Rate 1004 Kbps
Audio:
MPEG AAC Audio
Bit Rate: 64 Kbps
tletter
I'd suggest that you strip out the audio from the clip, edit it using an audio editor, and then add it and the video track back into VS.DayO wrote: Audio is more characterized as scratchy, not buzzing.
DayO wrote:Attributes: 24 bits, 450x800
Perhaps your source is Whatsapp or a smartphone. In any event, you could simply export it using OpenShot and then further edit it in VS.DayO wrote:Yet when I imported the clip into an Open Source video editor--Open Shot--the clip payed back just fine, with the audio track without the buzzing
tletter
DayO
- ram: 32 GB
Yes, the full clip was a Facebook Livestream, recorded on a Smartphone to FB.
Good idea, export now from Shotcut, an Open Source video editor, then import to VS Pro...
Let's see how that works out.
tletter
The use of HandBrake is an alternative.DayO wrote:export now from Shotcut, an Open Source video editor, then import to VS Pro...
tletter
DayO
- ram: 32 GB
OK, will check out.
