Mercalli VS 2021
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Mercalli VS 2021
Post by pepegota »
Mercalli is not working in VS 2021. No problem with VS2020. Video specs:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 16 min 50 s
Bit rate : 2 500 kb/s
Width : 480 pixels
Height : 480 pixels
Display aspect ratio : 1.000
Frame rate mode : Constant
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.362
Stream size : 296 MiB (93%)
Writing library : x264 core 133
I cut two clips from the video and applied Mercalli. I rendered to the first clip criteria. Therfore, there was no change from the original.
However, Mercalli insisted on a rerun. I did the same thing in VS 2020 without issue. Concliusion, Mercalli VS2021 is not functional
compared to VS 2020.
Re: Mercalli VS 2021
Do you have more than one Mercalli in your VS 2021 FX folder? I have Mercalli RT 5, which I think is what is installed with VS 2021 (and backwards installed on previous versions of VS on that computer). I also have Mercalli Pro, which I am pretty sure is an updated version of what came in previous versions. As I said in an earlier thread https://forum.corel.com/viewtopic.php?p=385666#p385666 I didn't think what we now had in VS 2021 when it came to Mercalli was very effective.
In that thread, by the way, you already expressed your disappointment that we had to revert to earlier versions of VS to get an effective Mercalli.
I had already bought Mercalli 4 as a stand-alone program, and upgraded to 5 without paying anything, following proDAD advice. That's the one I still use and it is effective.
I'm also not sure if Trevor ever got a response from Corel on this.
Please view this post by Snake11, is this the same issue
Glus from Corels development team also commented here,
https://forum.corel.com/viewtopic.php?p=385757#p385757
As far as I know this problem has not been fixed with the latest service pack, disappointing.....
pepegota
ram: 64 GB
Post by pepegota »
This egregious behavior must be corrected and ASAP! This is an important part of the program. Corel get on your horse.
