Hello
Videostudio now exports MOV videos with transparency ( Like animated overlays ) , and can re-import it easily.
But how to to import videos made in other softwares ? Which settings are accepted in Videostudio, to be put in timeline to interact with other tracks, AND to be seeing with transparency ( not the usual black background ) ?
I don't want to use chroma key. I just want to import the videos as the ones made with Videostudio ( Alpha channel video option in the Share ).
And, which settings are put in the MOV videos exported by Videostudio ? ( Codec, bitrate, etc ) Maybe we could try to match that to the videos made in other suits, to be 100% compatible with Videostudio.
Thanks for any help.
How to import videos with alpha ( transparency ) into Videostudio?
cybernick
- Video Card: GTX 1060
- Hard_Drive_Capacity: 1TB nvme
- Corel programs: Video Studio 2020&2021 Ultimate
Re: How to import videos with alpha ( transparency ) into Videostudio?
I am using an alpha output in my projects and the specs are as follows.
In order to import just add in the media lib and then drag it to the overlay in timeline.
ormat : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.02 (qt )
File size : 2.63 GiB
Duration : 5 min 0 s
Overall bit rate mode : Variable
Overall bit rate : 75.3 Mb/s
Encoded date : UTC 2021-04-06 20:22:48
Tagged date : UTC 2021-04-06 20:22:48
Video
Format : CineForm
Codec ID : CFHD
Codec ID/Info : CineForm High-Definition (HD) wavelet codec
Bit rate mode : Variable
Bit rate : 75.3 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : RGBA
Bit depth : 12 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 1.452
Stream size : 2.63 GiB (100%)
Language : English
ormat : MPEG-4
Video
Format : CineForm
Codec ID : CFHD
Color space : RGBA
Bit depth : 12 bits
Language : English
Hmm, thanks Cybernick
I'll try to match that and test it here.
