Paint brush tool
hector-1
Corel programs: Corel PaintShop Pro X7
Paint brush tool
Post by hector-1 »
(Paint Shop Pro X7)
Hello friends,
I am using the paint brush tool to create a white background for a picture of a box. I am using the square shape with smart edge.
My problem is:
When I rotate the square its sides turn dentate and the edges of the image do not look well.
Please help me, how I could avoid the square gets dentate when I rotate this :?:
Thanks in advance for your help.
Hector.
migf1
operating_system: Windows 8.1
Re: Paint brush tool
Post by migf1 »
Can you provide an example (ideally showing the before and after)? There may be better alternatives to achieve what you are going for.
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
JoeB
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
@migf1: I believe that @hector-1 is referring to the fact that when he rotates the square brush shape less than 90 degress the edges of the the brush and therefore the paint has pixelated/jagged edges.
@hector-1, I have a question. If you are trying to create a white background why don't you just flood fill that area with the the flood fill tool using the color white?
JoeB
Using PSP 2019 64bit
hector-1
Post by hector-1 »
Hello friends,
Thanks for your replies.
I have used "flood fill tool" to to create a white background, but this doesn't get a full whitening. See attached screenshots.
In order to whiten outside the edges of the object I use the paint square brush tool, but when I rotate this, its sides turn dentate and the edges of the image do not look well.
How could I avoid the sides of square brush tool get dentate when it is rotated?
Hector.
Ugly Image finish
Ugly Image finish
Background partially whitened
Square brush tool dentate 2
Square brush tool dentate 1
migf1
Post by migf1 »
Hi hector, thanks for the screenshots!
To smooth out the brush edges try dropping its Hardness setting (even down to 0). If the image is not huge and you care for fine details, you may also try dropping the Step setting down to 1 (if that slows down the brushing, dial it up to 10 again).
An alternative approach could be to cover the areas to be whitened with a shape, using the Pen tool with stroke-color set to white and anti-alias box checked, along with the fill-color set to white.
Yet another approach could be to select the desired areas with the Freehand selection tool in Point-to-Point mode, probably adding a little bit of feathering or smoothing too, and then flood-fill the selected areas with white color (feathering and smoothing can also be done after you select the areas, from the menu: Selections -> Modify -> Smooth, before flood-filling them).
Ps. Hi JoeB, thanks for clarifying hector's question.
