blur object
vasilis
- sound_card: nvidia GTX 2060
- Hard_Drive_Capacity: 500 gb
- Monitor/Display Make & Model: ASUS G731GV
- Corel programs: VS 2020
blur object
Hello.I have video studio 2020.I want to blur a merged text at a video.I see the guide at link :https://www.corel.com/en/tips/video/bas ... video/.But i don't understandn much.
Is there any video tutorial or smoething like that?Also i the manual as pdf to my c drive.By mistake i have deleted.How can redownload it?
Re: blur object
Running Video Studio go to Help – User Guide should take you here:-
https://help.corel.com/videostudio/v23/ ... o-2020.pdf
You can also use Help – Help Topic
https://help.corel.com/videostudio/v23/ ... index.html
Blur
As you are using on a video, does the effect that need tracking, in which case you may need Track Motion
FX filter library has Blur filters, in addition a New Blue Pixilator that may do what you want.
Blur
vasilis
Re: blur object
Τhank you for your responce.
About Guide:
1) The help topic is more comprehensive guide?From original guide?How can have acess via site ?I open this link but i wonder how can have access from site
2)With blur and track motion can i create multi blur at scenes?Also when add tracking the video reproduced from the beggining.And is very large,1 hour....Can i create a second short clip to add blurring and adding as overlay to original video ?To avoid reproduction?
3) How can add a filter to timeline?Simply drag it over the video clip in timeline?
About Guide:
Re: blur object
1 / If you wish to save the Help Topic to your computer
Open the Help Topic on your browser, I used Edge
I press keyboard Ctrl+ P which opened the printer panel
Top left choose your printer as “ Save as PDF ”
2 / The video at 1 hour duration seems to me quite long to apply tracking.
You can use the scissors to cut the video into smaller clips, then apply separate tracking to each clip.
3 / To add a filter, yes I simply drag and drop from the FX library
vasilis
Re: blur object
Thank you for your responce
1)Which is the difference between pdf guide and online help topic?Is one more detailed than the other?
2)The guides (as pdf or online topic) are available at the site?If for example if i have uninstalled VS and i don't have downloaded it as a pdf...The guides (also for the previous versions of video studio) are available at Corel's site?
3)Ιs a movie and a person speak italian for a few seconds.How to blur the text at the specific scene without reproduction from the beginning?
4)After dragging to the timeline how to use the filter?
Re: blur object
Are you saying that your video has sub titles showing at the bottom of the video and wish to remove those or blur the text so it is unreadable?
Can you provide a screenshot, an image of your video frame
vasilis
Re: blur object
Yes.I want to blur .It's 2-3 scenes
Re: blur object
Can you provide a screen shot that may show more detail as to your problem
1 / If you are obscuring text at the bottom of the frame you can simply add an image to the overlay track, resize to match.
There is a mosaic type bmp in the X10 folder (M37) which could work.
C:\Program Files\Corel\Corel VideoStudio X10\Samples\Image
2 / If the text is at the bottom then you could resize the frame to hide the text
3 / you could try using mask creator to remove the text, although you would need another image to fill the space
You say 2 – 3 scenes, are these short a few seconds or long 30 minutes etc.
vasilis
Re: blur object
are few seconds.Also i would ask you something else.When close the program and reopne appears the home page.Now when reopen appears the capture page as first page.Can i ake again aa default opening page the ''home '' page?Also i have v 2020 not X10
Re: blur object
Press F6 on the keyboard will open the options panel
here you can set the Default Start Up Page, as attached Image.
Can you provide a screen shot of the text you wish to obscure
Apologies for reference to X10, the image M37 is also available using 2020
vasilis
Re: blur object
Oκ.Τhank you.For now i have left beside the blur issue.i have another issue :
1_after converting to H.264 the audio is how can i say .....distortion,scrubbing for a few seconds when a car speed up .Can i fix it?Always i use teh settings at the screenshot.
Also i would ask you :
2)Why when open the project settings appears by default the ''mobile'' option?
a)Also related to it : when drag the thumbnail to timeline appears the message if i want tp change the setting to match with project....something like that.When i clik yes and inserting subtitles i sould choose bigger font size(i use calibri) usually 43 to appear enough big the characters to my tv.Also if i choose for one time ''to match with project'' all the next projects ''follow'' the same settings.How can reset these settings?
b)if i don't choose mathcing the settings the normal font size for my tv is 28-29......
c)The audio distortion due to this matching or something about project settings ?
This is second project that appears distortion.Generally i don't have any issues
Re: blur object
A lot of issues here, all may be related to matching the Project Properties, or not
1 / Not sure but you should be able to reduce the volume of the car if that is the problem.
Or is the sound distorted, could be the original video quality.
2 / The project Properties panels always opens in the same format as your project
Think of the Mobile and Online options as Mpeg4
So if your project is set to Mpeg4 then it will open in Mobile.
2 a / a bit more involved
If your last project was say using 720 : 480 ( low resolution) set a few titles
Then change the project properties to use 1920 x 1080 then the titles / text will appear to reduce in size, The size of the text is relative to the resolution of the frame.
Using the text editor will choose the last used settings, if those were to add text to 720 x 576 and you then open a 1920 x 1080 then you will have to change the font size.
How can you address this, make sure your project properties match your video.
Unfortunately if you start a new project using a smaller or larger resolution then you will have to change the font sizes.
2b / Not choosing to change the properties to match seems to me that you have been working with different resolution video
In most cases 99% of the time we should always choose Yes to match the project properties.
However if you use a lower resolution video maybe you should choose No to retail the HD settings.
Clear as mud
2c / Yes the audio distortion could be the original video and project settings that do seem to be mixed?
I notice that the audio is mono, rendering the project may use stereo, I am unsure if that may be a problem?
Always use Yes to the message
From Share use Same as project Settings or Same as first video Clip, which ever is most appropriate.
Your second Image shows using AVC/H.264, these settings are for MTS video
So It appears you have both Mpeg4 and MTS settings
What are the actual properties of your video files?
Clear as mud
vasilis
Re: blur object
I am not sure how can find them?Also i would ask you the setting '' enable audio while scrubbing'' what is exactly?By default is unmarked.Should enable it or not?
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: blur object
See https://www.youtube.com/watch?v=HjMV-mZBoAsvasilis wrote: Also i would ask you the setting '' enable audio while scrubbing'' what is exactly?
Totally your call.vasilis wrote:Should enable it or not?
tletter
