This third image is not the same size as the two others.
Help Creating a Script for Enhancing Old Newspaper Photographs
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: Help Creating a Script for Enhancing Old Newspaper Photographs
ShopPaint
- processor: Intel R Core TM i5 10400 CPU 290GHz
- Monitor/Display Make & Model: HP S2031a
- Corel programs: PaintShop Pro 2020
How do you mean exactly mate? I don't think they are all going to be the same size.
Do they all need to be the same "size" before using them with a script? Thanks.
Jean-Luc
They need to have a similar size because the tools used to correct the halftone dots are size-dependent. If I resize your last image (320x476 pixels) to 800x1190 pixels (size similar to your first images), the halftone dots increase in size and the correction applied to the first images gives a bad result with the resized image.
I think it will not be possible to create such a script. Each image needs a different action with different settings.
I worked with your last image and the best I can do is below. It is done manually:
1) apply Fast Fourier Transform (FFT) filter
2) remove manually the "spikes"
3) apply inverse FFT
4) remove some noise with Adjust/Digital Noise Removal
5) apply Adjust/Add-Remove noise/Salt and pepper filter
The three first steps cannot be scripted.
ShopPaint
Thanks for taking the time Jean-Luc it is appreciated, i will try this over the weekend and see how long it takes me,
regards,
Peter.
regards,
Peter.
