Now on to the next task. The video is about 20-25 minutes long and they used 3 camera's two I think with incandescent lights. I want to adjust those sections of the video.
I do not recall having to trim each section in order to get the color editing to come up. I tried a few things with out any luck. It seems multi trim may be my easiest way?
There are at least 10 sections that I want to fix the light and color on.
As always appreciate your assistance.
Thanks Bruce Leavitt
Video editing colors in certain sections
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: Video editing colors in certain sections
Which version of VS are you using? Your profile is mute on that point.brucefl wrote:I want to adjust those sections of the video. I do not recall having to trim each section in order to get the color editing to come up.
Suggest that you split the video into sections that need colour adjustment, and apply filters to adjust the colour as required. Of course, you can copy and paste attributes between sections that need identical adjustments.
tletter
gewb
- motherboard: MSI Pro B550-VC
- processor: AMD Ryzen 7 5700X
- Video Card: ASRock Radeon RX 6650 XT
- Monitor/Display Make & Model: LG 24MK430
- Corel programs: 2018, 2021, 2023 Ult.
Bruce is using VS2021 based on statement in a previous topic post.
Bruce - please go into your forum User Control Panel > Profile > Corel Programs and enter/correct the information.
gewb
Bruce -
1. Double-click the desired video clip on the timeline; the editing pane opens.
2. Click the Color tab.
3. Click the Basic button if it isn't already selected.
4. Adjust the desired color parameter.
5. Click outside of the edit pane to exit edit mode.
brucefl
- motherboard: I7 3770
- processor: 3-4 Gig
- ram: 12gb
- Video Card: NT Geoforce 640
- Hard_Drive_Capacity: 2 T
- Corel programs: VS21 VS18thru21 and more PIX13
Profile is corrected and added, looks like it will be easier to split the sections up. Thanks
cybernick
- Video Card: GTX 1060
- Hard_Drive_Capacity: 1TB nvme
- Corel programs: Video Studio 2020&2021 Ultimate
I would suggest to use a LUT since it is fixed an easier to apply to multiple sections.
