I use 2 videos and one audio in muticam editor. Video is 1080p 50fps XAVC and the audio is wav 24 bit audio. And files have smartproxy.
After the muticam edit if you put the multicam.vsp in the timeline flatten (by holding the shift) the render (with exactly the same setting with the source files) is muddy.
But if you put the VSP regularly without flattening the render quality is good.
I tested in both nvidia and Intel HW acceleration mode. No change.
Dear community please also test it. If you have the same result it should be communicated as bug.
We know that flatted VSP insert have issues . This will be another one
