PaintShop Pro 2021 Crashing
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: PaintShop Pro 2021 Crashing
Post by Jean-Luc »
ArecJohnson wrote: Thu May 06, 2021 12:17 pm I am also facing the same issue with my PSP 2021. Do I need to reset it?
If a font issue, a reset will do nothing. Font issue needs to remove the fonts which produce the problem.
rmpinheiro
motherboard: AsusTek Computer Inc H87-PRO Intel PCH H87
processor: Intel Core i7-4770 CPU 3_40GHz 3_40 GHz
ram: 24GB
Video Card: NVIDIA GeForce GT 640
sound_card: High Defin Audio Device AND NVIDIA High Defin Aud
Hard_Drive_Capacity: 5546 GB
Monitor/Display Make & Model: BenQ BL2410 (Generic PnP Monitor)
Corel programs: PSP 2019 + 2021, VideoStudio 2020, CDraw
Post by rmpinheiro »
Hi ArecJohnson. As I am not an expert in this area I tried everything that was within my reach and that did not seem to cause significant damage to the SW of my PC. I also did a reset of the PSP 2021 parameters, but at a later time I think there would be no need.
My suggestion is to start with fonts.
1. Run the PSP and try to use the Text tool. Move the cursor over the font name multiple choice box. Pay attention to the name of the last font that appears in the list before the PSP disappears. In my case it was a font with the name "DFPOP1-W9" and others that were together and also started with "DF". Of these I did not take note.
2. Go to Widows / Fonts and delete that font or move it to a directory that will serve as a backup, which can be useful in case you want to revert everything that has been done.
3. Run the PSP again and follow steps 1. and 2. until the program works normally.
Note: Before doing what I now suggest, I followed the suggestion made by Wykkyd, post above, and this led me to eliminate 2 fonts that on the PSP showed a blank preview.
Tell us how the attempt went.
ArecJohnson
operating_system: Windows 8.1
System_Drive: M
Post by ArecJohnson »
rmpinheiro wrote: Fri May 07, 2021 11:04 am Hi ArecJohnson. As I am not an expert in this area I tried everything that was within my reach and that did not seem to cause significant damage to the SW of my PC. I also did a reset of the PSP 2021 parameters, but at a later time I think there would be no need.
Hi thanks for detailed guide, I will implement them and then will tell you. I hope problem will solve by this.
splash3313
Hard_Drive_Capacity: 1tb
Post by splash3313 »
First solution uninstall and reinstall all Visual Studio Redistributable modules.
https://support.microsoft.com/en-us/top ... f26a218cc0
Could be a corrupt Visual C++ that's causing the crashes.
