Problem Importing video file into 2021 Ultimate
RobCharles1981
- motherboard: MSI MAG B650 TOMAHAWK
- processor: AMD Ryzen 7 7800X3D
- ram: 32gig DDR5
- Video Card: XFX 7800XT
- sound_card: Sound Blaster Z
- Corel programs: Studio Ultimtate 2023
Hi all,
So I've gotten 2021 Ultimate and had it now for a few weeks or so and it seems to behaving itself.
Now I'm working on a project and have bunch of video files which are in MTS format and play perfectly in VLC Player. And when I attempt to import the files into the program I get an error message which I will attach to this post.
The only thing I will have to do is to convert into another file format any good free programs and retain it's quality?
But ideally Corel should be noted for this error which should be fixed.
Any suggestions would be most welcomed!
Rob
Rob
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: Problem Importing video file into 2021 Ultimate
HandBrake will do this.RobCharles1981 wrote:I will have to do is to convert into another file format any good free programs and retain it's quality?
tletter
RobCharles1981
- ram: 32gig DDR5
Thanks I will check it out!
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Rob, VS2021 has no issue with mts files, can you attach your video properties
- Davidk
- ram: 16Gb
- Hard_Drive_Capacity: 6Tb
Something that may be relevant is the device your mts files came from. Sadly, what appears to be a standard may not be - vendors are notorious for 'tweaking' a file format to make their device look good, or better, but there are so many digital file variations around, this device/format may not be supported by VS.
Corel Support would not normally visit here so if you want Corel to fix then you should contact Corel Support as you should be aware we do not work for Corel.RobCharles1981 wrote: ↑Fri Mar 19, 2021 12:12 am
First can you provide a sample of the video, you will have to upload to a sharing site, Google Drive, Drop Box etc.
We can then test your video to prove its is ok or not
That leaves your program which you should re-install to see if that cures the problem.
It may be your pc's environment, although I assume your older program had no problems, but has anything changed to your computer, installing updates, codec packs, driver updates?
Like Robert I have no problems working with MTS files
TonyP
- motherboard: Gigabtye X570 Elite
- processor: AMD Ryzen 9 5950X 16core 32threads
- ram: 32GB 3200
- Video Card: Sapphire RX 6700XT 12GB
- Hard_Drive_Capacity: 10TB
- Monitor/Display Make & Model: LG 27" IPS 4k, Acer 24" 1920x1080
- Corel programs: VS2023, PSP2023, Aftershot 3
I have old MTS files from a Canon camcorder that work without any problems in VS2021.
tletter
I've incorporated many MTS files in VS and most have no problem, but occasionally some of the files can't be added into VS although they play w/o issue in video players. These problematic MTS files are converted using HandBrake and then added to VS.RobCharles1981 wrote: Now I'm working on a project and have bunch of video files which are in MTS format and play perfectly in VLC Player. And when I attempt to import the files into the program I get an error message
tletter
cybernick
- Video Card: GTX 1060
- Hard_Drive_Capacity: 1TB nvme
- Corel programs: Video Studio 2020&2021 Ultimate
Can it be something with HDCP protection enabled in the recorder?
In any case I would suggest to install k-lite to your PC if you do not have yet.
TonyP
- ram: 32GB 3200
Is it possible to upload a sample of a problematic file to the cloud? Everyone can download it and see what happens on their computers.
RobCharles1981
- ram: 32gig DDR5
Hi all sorry for the delay.
Here are a couple of files attached to my mega storage - I then had to convert the files in the end.....
https://mega.nz/folder/hUwggAJJ#vwt4IRFTY_2nyyvZKwVuVA
TonyP
- ram: 32GB 3200
First, can you put them on something like Google driver where I don't have to accept tracking cookies to download?
Next, these are original MTS files that are problematic for importing, correct?
RobCharles1981
- ram: 32gig DDR5
I don't have google drive sorry.
Yes those are the files.
Candive
- Corel programs: VS2021, VS2023, PSP2021, ASP3
I downloaded your first sample file and can confirm I could not play it in VS. But the file can be played in other video editors including Corel's other editor Pinnacle Studio.
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
X9 and I guess all VS's see these files as wireless B/W BMP's....
If they were wired colored BMP's than they could be admitted
Panasonic X900m, VXF1
