VideoStudio 2020 Cannot Add More Folders
Bolosun
motherboard: Gigabyte Z690 Gaming X
processor: Intel i5 12600K
ram: 16gb
Video Card: Nvidia GeForce RTX 2060 Super 8GB VRM
sound_card: Creative Soundblaster Z
Hard_Drive_Capacity: Loads
Monitor/Display Make & Model: AOC Q3279WG5B
Corel programs: VideoStudio Ultimate 2021, Aftershot Pro
Post by Bolosun »
I have tried searching to see if this has been asked before, but get 20+ pages of spurious results.
So here goes.
Tried to add another folder under the media tab, and I have already Background, samples plus 4 of my own, but it wont let me add any more folders. Is there a limit?
Re: VideoStudio 2020 Cannot Add More Folders
I do not know if there is a limit but others have raised the issue of adding folders although when adding more than 99
If you have only added a few then there should be no problems in adding more, I do not normally use many additional folders, only the ones I need to use, so not to store my media files
I have probably added 20 in the past with no issues
What version of Video Studio are you using, your profile shows 2020, can you confirm
Can you take a screen shot of the media Library showing the error message
Candive
Corel programs: VS2021, VS2023, PSP2021, ASP3
Post by Candive »
I think the limit is around 40. And even if you reach this limit, I think you can add at least one sub-folder to each main folder. It doesn't sound like you used your limit. You may need to reset your Library (under Settings) but before you do, export your current Library. Reset your library. See if you can add more folders to comfirm. Then re-import your original library to see if that doesn't fix the problem.
Bolosun
ram: 16gb
Post by Bolosun »
Thanks for the response, I only have 9 folders!
And here is a pic of the error - I am using 2020 Ultimate
I have just added 30 folders then I received the warning, I was then able to add Sub Folders but only one for each main folder
If a Library reset as recommended by does not fix this you can try resetting the program by re-naming the 23.0 folder assuming you are using 2020
Just noticed your last reply
Thanks for the image, you appear to have added Sub folders, How many?
One shows as 31453, did you name the folder ?????
Bolosun
ram: 16gb
Post by Bolosun »
Including all of the sub folders, I have 48 folders
I added 11 folders each one having 3 subfolders and hit the limit
Bolosun
ram: 16gb
Post by Bolosun »
I have reset the library and I can add folders again. Obviously all of my original folders have now gone.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Bolosun wrote: Wed Mar 17, 2021 1:38 pm Including all of the sub folders, I have 48 folders
You have 9 more than I can have.
Panasonic X900m, VXF1
Bolosun
ram: 16gb
Post by Bolosun »
Wonder why the limitation?
Candive
Post by Candive »
Bolosun wrote: Wed Mar 17, 2021 1:48 pm I have reset the library and I can add folders again. Obviously all of my original folders have now gone.
As I indicated in my previous post, if you want to keep your original library folder structure before resetting the Library, export your Library and then re-import it after the reset.
It appears you have reached the program limit.
Bolosun wrote: Thu Mar 18, 2021 1:27 pm Wonder why the limitation?
Video Studio always had a folder limit in its Library. I believe most forum members use the Library as "project bins." Once the final video is complete, the project bin (folder) is deleted. I suspect they use Window's folder structure to manage their source data. Corel's other video editor; Pinnacle Studio has a more comprehensive Library where you can store assets in Collection bins as well as Project bins.
