Corel Discovery Center links to the Corel Web Site
Corel User Guides in PDF
VideoStudio Pro
Corel VS X9 User Guide (12.88 MB (
Corel VS X10 User Guide (14.8 MB PDF)
Corel VS 2018 User Guide
Corel VS 2019 User Guide
Corel VS 2020 User Guide
Corel VS 2021 User Guide
Corel VS 2022 User Guide
Video Studio Hotfixes and Manuals
Program Manuals
Reason: Out of date info
CVSX7 -- Fix for Vimeo log-in
Corel have provided a replacement file as a fix for the Vimeo login issue
I assume this will be included in the next service pack.
Copy the appropriate uSocialService.dll file ( 64 bit or 32 bit) and paste to your
Corel\Corel VideoStudio installation folder
I would suggest re-naming the original to “uSocialService old.dll”
Although I doubt if you will require that file again?
Hope this helps
Hope this helps
Hot Fix for CVSX7Mov /MP4 issues
Hello
There have been some problems in using MP4 and Mov, Corel have brought out a Hot fix available from their web support pages, however I did have problems downloading from Corel.
http://howto.corel.com/en/corel?family= ... mp4lib.dll
There are many different types of Mov and MP4 video files so I am not sure if this fix covers your particular files but is worth a try.
I have attached the file and install info to this post
CVSX 9 and 10 MCE Issues
A problem occurred when adding video files greater than 1 hour duration.
Corel have provided these hot fixed for X9 and X10.
This post on the open forum refers.
http://forum.corel.com/EN/viewtopic.php ... 55#p340434
If you have problems please download the appropriate zip file below.
This contains a uvMultiCamDB.dll file
Replace the existing file, I would first suggest re-naming the original as uvMultiCamDB_old.dll
Then paste the new file to the folder.
C:\Program Files\Corel\Corel VideoStudio X10
C:\Program Files\Corel\Corel VideoStudio X9
Corel Video Studio X10 / 2018 and 2019 Not launching
This fix is valid only for installations of Videostudio X10 & 2018, Pro and Ultimate. This fix was not developed for previous versions. If you are running anything other than X10 & 2018, please be advised that there was no updated fix for this issue, and the only course of action we (Corel) have to offer, is a suggestion of an upgrade to the latest revision.
Post Updated 11/10/2019
It appears that for some users CVS2019 is also suffering the same fate as X10 and 2018
This fix has proven to be successful when applying to CVS2019
Instructions to replace file:
1. Download file "iEncoder.dll" from here:
http://cdn.pinnaclesys.com/SupportFiles ... ncoder.zip
2. In Windows Explorer, browse to C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG
3. Extract the DLL file into this folder.
4. Start Corel VideoStudio.
alternate download
alternate download
CVS 2019 Unable to open VSP then program crashes.
A hot fix was provided to one of our forum users
Please read this post by MindFlareRetro,
viewtopic.php?f=1&t=66176&p=373671#p373653
Corel Support have provided a hot fix that appears to allow problem VSP’s to open
Also indicates that it may fix some crash issues
To apply the hotfix.........
1. Close Video Studio 2019 if it is open
2. Navigate to C:\Program Files\Corel\Corel VideoStudio 2019
3. Locate the existing HerDocdll.dll file and rename it (e.g. HerDocdll-old.dll) and/or copy it to another location
4. Extract the new alternate HerDocdll.dll from the ZIP file and copy it to C:\Program Files\Corel\Corel VideoStudio 2019, replacing the renamed file (you might require administrative privileges to do this)
5. Re-launch VS19
5. Re-launch VS19
CVS 2021 Mercalli analyse -- fixed
A problem occurred causing Analyse to be required again.
Installing the attached file gave me version 5.0.518.1
Tests showed the problem being fixed.
View this post for details
https://forum.corel.com/viewtopic.php?f=1&t=68033
To install double click the mercalli_x64.exe file
Re: Video Studio Hotfixes and Manuals
Video Studio 2022 registration issues
Some users have experienced problems with the registration process
Please visit this article to reset the messages which may help.
https://kb.corel.com/en/128877
When registering make sure you are using your Corel account e-mail address, otherwise create a new account.
Post updated
this post by Gameway also refers
https://forum.corel.com/viewtopic.php?p=394403#p394403
Post updated
