Hi to all,
the question is simple anf direct:
I have an image (a simple square box) filled with RGB(255,0,0), to say completely red.
The color space is sRGB.
I save it as jpg with this options:
I do not run Optimizer
Now I reopen it (the dialog box says the ICC is none ... boh!):
I look at it and PSP says that the color is (254,0,0)!!
Please, why and there occurs this transformation? I did some test without any result.
Thank you.
PS. In 2015 there was a post "JPEG Optimizer Removes Embedded sRGB Color Profile" that in some way is related to my question: at that time the author seemed disappointed with PSP.
Why colors change after saving an image as Jpg?
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: Why colors change after saving an image as Jpg?
It is perhaps the normal behaviour of the JPG compression algorithm which is a lossy format.
If you do the same manipulation in Windows Paint, you will get the same 254 0 0 result when saving in JPG.
In Painter Essentials 7, when saving in JPG with sRGB IEC61966-2-1 black scaled profile incorporated, I get 255 0 0. When saving without this profile, I get 254 0 0.
Saving with PSP in PNG format gives always 255 0 0.
ilgk48
- Corel programs: PaintShop PRO 2019 32bit
Thank you very much, Jean Luc.
I'm thinking to use PNG from now
