Can we install Boris Graffiti on VS2021 Ultimate??
- Telmo
- motherboard: Asrock H370M Pro-4
- processor: Intel Intel I7 8700 4.6 Ghz
- ram: 16 GB DDR4
- Video Card: Geforce Gtx 1060 Gigabyte 6GB Windforce
- sound_card: C3 Tech
- Hard_Drive_Capacity: 1 Tera SSD
- Monitor/Display Make & Model: Realtek High Definition Audio
- Corel programs: Videostudio 2019 Ultimate
Hello, I've just upgraded from VS2018 Ultimate to the latest VS2021 Ultimate. I've noticed that Boris Graffiti was removed. Is it possible to install it back??
Re: Can we install Boris Graffiti on VS2021 Ultimate??
I don't really know as I never really used Graffiti. However, if I were to try, I would need to have retained VS 2018. Then I would look there into the Corel VideoStudio 2018 sub-folder vft_plug for the relevant Graffiti file or files and copy them to the vft-plug sub-folder of VS 2021. (I don't have VS2018 installed so I can't tell you what those files are.) You might also need to go to C:\Users\[YourName]\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)and rename the 24.0 folder to, say, 24.0_OLD so that it rebuilds with a reference to Graffiti when next you open VS2021...
I can't guarantee this would work. But it follows the "normal" way we would insert plug-ins from earlier versions into the most recent version.
- Telmo
- ram: 16 GB DDR4
Thanks Ken, I will follow your suggestion and give it a try.
- RobertOZ
- Hard_Drive_Capacity: 7 TB
I tried but wasn't successful, I think it may need BCC or some other Boris component installed
I suspect it requires something in C:\Program Files\BorisFX which the plug-in would link to. As I said above, I don't have VS2018 on this computer, so while I have, in BorisFX, a sub-folder called ContinuumCorel, there is nothing in vft_plug to link the two. For all I know, there might even be a direct reference to Graffiti in BorisFX or the ContinuumCorel sub-folder if Graffiti had ever been installed on this computer. So check to see what is in your own BorisFX if you haven't already done so.
Ken / Robert
I tried this a while ago when it was discussed with 212 and worked ok
I did copy from X10 as i did not have 2018 installed.
Yes i think we need the correct library files in the ProDad / Boris folder along with Graffiti4 in the vft folder, and that means having the correct video studio version iinstalled
I have the 2021 Trial installed so can test later, in about 12 hours
Choi seong chul
- motherboard: Asus Z390
- processor: InteCore i9 9900KF
- ram: 64GB DDR4
- Video Card: NVIDIA GeForce RTX 2080 Ti 11GB
- sound_card: MAYA U5 External Sound Card
- Monitor/Display Make & Model: LED Raantec 24"
- Corel programs: CVS X4,- X10,2018-2022,2023
Re: VS2021 Ultimate에 보리스 그래피티를 설치할 수 있습니까?
If you do it your way, Boris appears,
A red X appears and cannot be used.
Is there another way.
That's Boris Title Studio, not Graffiti...
Choi seong chul
- ram: 64GB DDR4
Boris Title Studio is right.
Because there is no Boris title in 2021.
I tried it the same way in 2020.
Yes, but the original poster wants Graffiti, which is different from Boris Title Studio... though I acknowledge that the same thing might happen with Graffiti from VS 2018.
Choi seong chul
- ram: 64GB DDR4
Bringing Boris Graffiti to VS2021 at VS2018
Can be used.
However, BCC Title Studio cannot be used.
Can be used.
- Telmo
- ram: 16 GB DDR4
Could you please elaborate how you installed Boris Graffiti to VS2021?? Thanks in advance.Choi seong chul wrote: ↑Thu Feb 25, 2021 1:19 am Bringing Boris Graffiti to VS2021 at VS2018
Can be used.
Choi seong chul
- ram: 64GB DDR4
Local disk C:\program Files\Corel\Corel Video Studio 2018\vft_plug\
Graffiti 7 vft. by copying.
Paste the same path in VS2021.
Choi seong chul
- ram: 64GB DDR4
In the same way, BCC Title Studio is a trial version.
Appear. You need to purchase a license.
We have to have a Video Studio program installed that supported Boris Graffiti, I believe that was 2018 although I only have X10 installed
This will install the library for Graffiti, I see this here
C:\Program Files\Boris FX, Inc\Keyframe Libraries 7\Graffiti 7 Keyframe Library
with X 10 installed in ….
C:\Program Files\Corel\Corel VideoStudio X10\vft_plug
You should find Graffiti7.vft
Copy that file to
C:\Program Files\Corel\Corel VideoStudio 2021\vft_plug
You should then have a working copy of Graffiti in the Boris FX category
For BCC Title Studio the process is the same
We have to have a Video Studio program installed that supported BCC Boris FX,
This will install the library for BCC Boris FX, I see this here
C:\Program Files\Boris FX, Inc\BCC Presets 10 Corel
You should find BCCTitleStudio.vft
Copy that file to
You should then have a working copy of BCC Boris FX in the Boris FX category
Copy that file to
Copy that file to
