Hi to all,
I have just realized that in the Customize->Toolbar window, my personal toolbar named "myColor Replace" occurs four times!
In effects PSP 2019 permits duplicated names (boh!).
Well, only the second "myColor Replace" is associated to the toolbar, so let's go to delete the others: not possible!
If I try, PSP correctly asks "Do you want ... " ecc. but when I confirm nothing happens. The name remains.
Why?
Please, any ideas?
Thank you.
Duplicated custom toolbars name
Re: Duplicated custom toolbars name
I had the exact same issue with PSP 2020 I think (could be 2019, don't remember). Levi suggested that my registry could have been corrupted, regarding my custom workspaces. I ended up re-creating my workspaces from scratch, avoiding adding custom toolbars. Instead, I created custom menu-like groups of tools.
Good Unofficial PaintShop Pro Tutorials: Creation Cassel • Make Shop Pro • HEC Image Editing • LeviFiction PSP Basics
(plus my own Gimp & Stuff)
ilgk48
- Corel programs: PaintShop PRO 2019 32bit
Many thanks!
I've deleted from the registry the keys associated to the toolbar "myColor Replace" and now it is disappeared from the window "Customize".
Ehm ... you created custom menù? At a glance I do not find how you did this. Custom toolbar yes, obviously.
There is a special command for that in the View -> Customize dialog: http://prntscr.com/zq7ywr
EDIT: Actually, it is the "New Button Group", right below "New Menu".
ilgk48
Ok. Found.
Help does not help at all ...
Now I click "new menù" or "new Button Group" ... and then?
Please where can I find this subject in the Help?
Frustration ...
... Ah! OK. Just found by attempts how to use.
Frustration ...
Nice, glad it worked out for you too. I also think that's more elegant then toolbars, but that's just a personal preference.
ilgk48
Yes, elegant and not too intrusive in the window.
Thank you again.
Thank you again.
You are welcome!
