Save copy as
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Save copy as
Post by Jean-Luc »
The help file doesn't explain the difference between 'Save as' and 'Save copy as'.
I don't understand where is the difference. :?:
Does anyone know?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Save copy as
Post by LeviFiction »
I'm not going to describe this well. But essentially it creates a copy of the current image and edits inside PSP without changing where the currently opened image points to on the HDD.
Save As saves the current image with a new filename. That filename is then reflected in the Titlebar as the open image now refers/maps to that new file location and name. So if you hit Save it saves to that file specifically.
Save Copy As creates a new file using the current image but the open image in PSP does not get mapped/refer to this new file. So, when you hit Save on the current image it won't touch the copy you'll be saving over the currently opened image.
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: Save copy as
Post by Forriner »
Also, as far as I can tell, Save as... defaults to the folder an image was opened from, like Save, while Save Copy As defaults to the last 'save copy as' folder.
Jean-Luc
Re: Save copy as
Post by Jean-Luc »
Thank you Levifiction. I could have found it myself. I hadn't really performed the operation. I had stopped at the settings window which was the same in both cases. :oops:
Jean-Luc
Re: Save copy as
Post by Jean-Luc »
Forriner wrote: Sat Feb 13, 2021 10:29 am Also, as far as I can tell, Save as... defaults to the folder an image was opened from, like Save, while Save Copy As defaults to the last 'save copy as' folder.
Thank you, Forriner. :)
scottb613
motherboard: Gigabyte
processor: i7-7700K Kabylake OC 5 Ghz
ram: 32GB
Video Card: EVGA GeForce GTX 1070 Ti
Hard_Drive_Capacity: 2000 GB
Corel programs: Jasc PSP 9.1 - now PSP x9
Re: Save copy as
Post by scottb613 »
Hi Folks,
"SAVE COPY AS" Also remembers the file type - when working on things like 3D Models and such - I typically use "SAVE AS" for my main PSP file [pspimage] saving it securely in one location as you want to insure your source is saved properly all the time. The I use "SAVE COPY AS" in the format I am using on the model like DDS - saving it to my models working directory. I think it's real intention is to help prevent you changing your [pspimage] file to something else - then accidentally saving it and then exiting - losing your [pspimage] format.
Scott
