Flash file support (swf)
Choi seong chul
motherboard: Asus Z390
processor: InteCore i9 9900KF
ram: 64GB DDR4
Video Card: NVIDIA GeForce RTX 2080 Ti 11GB
sound_card: MAYA U5 External Sound Card
Monitor/Display Make & Model: LED Raantec 24"
Corel programs: CVS X4,- X10,2018-2022,2023
Post by Choi seong chul »
Who can help, Video Studio removed Adobe Flash Player, then swf files are not supported, you can also use template\HTML5 entries from 2020. Mixed flash files (swf) and swf files are no longer available. Is there a way?
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Flash file support (swf)
Post by asik1 »
It's not VS it's Adobe and windows that removed Flash Player.
You can try by setting your OS date to 1.1.2021 and see if it works.
Panasonic X900m, VXF1
Choi seong chul
ram: 64GB DDR4
Thank you. Thank you.
OS date is changed to January 1st, 2021 and it works.
What should I do to continue working in the future?
Flash files (SWF) will no longer work with any editor, reverting the time is just a workround.
You can convert the SWF to I would suggest Mov Alpha, then replace the SWF in the project.
Of course Corel are a bit slow to address the use of SWF files as some templates using SWF are still available to use.
I doubt Corel will fix these templates, just simply remove them, eventually.
As far as I know only Html 06, 09 and 10 are SWF free
20 out of 85 of the free Get More templates are using SWF.
Some of the programs Templates Instant Projects use SWF
If you can identify the SWF files in your project, I may be able to upload the appropriate alpha Mov, they should work?
I did convert 65 swf to mov , 5.6 Gb
Choi seong chul
ram: 64GB DDR4
Thank you to everyone. After the date change, I changed the swf file to a mov file. However, I cannot modify the swf file of the template, thanks.
what are the names of the SWF files
Choi seong chul
ram: 64GB DDR4
File format: Macromedia Flash Files.
You should be able to use VS 2019 to convert the SWF to Mov
Although your image seems to indicate you have done that
I believe the files in your project are called
HTML 02_Object 01.swf
HTML 02_Object 02.swf
I have converted to Mov they are 20 Mb so to large to attach to the forums.
The files you are using in your project should be here
C:\Users\UserName\Documents\Corel VideoStudio Pro\VSPTemplate\HTML 02
Choi seong chul
ram: 64GB DDR4
Corel's answer
Thank you for contacting Corel Technical Support.
Sure Regarding this I will check with my higher level technician and let you know the status
SaravananVontlinVijayaraghavan
Corel Customer Support Services
Thanks for the info, interested in what Corel have to say, please keep us informed.
If you do need any specific files to replace the SWF I may be able to provide
Choi seong chul
ram: 64GB DDR4
Corel answer.
SaravananVontlinVijayaraghavan (Corel)
Feb 3, 2021, 9:34 EST
Mr. / Ms. seong,
As per your concern the Flash objects that you are referring is disabled from the VideoStudio and we are looking for the update
