Use Foreground Color In ColorChanger
Pahrump
Post by Pahrump »
I am trying to write a script that:
opens an image that is essentially a monochromatic chip or sample
crops a rectangle from that image
resizes the canvas around the rectangle
pastes a saved image into the canvas
uses the eyedropper to set the foreground color to the color of the rectangle
changes the color of the pasted-in image to the color of the rectangle (foreground color set by the eyedropper)
saves and closes the image
The problem I am having is I don't know how to change the script that I have saved after going through these steps so that the color changer uses the color from the eyedropper. I need it to be variable. But all that happens is the color of the very first image used when I recorded the script is used again and again.
I assume that this line needs to be changed, but I don't know to what:
'Color': (220,224,16),
Here is the entire script:
from PSPApp import *
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'PaintShop Pro',
'Host Version': u'23.00'
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Default,
'AutoActionMode': App.Constants.AutoActionMode.Match,
'Version': ((23,0,0),1)
# Crop
App.Do( Environment, 'Crop', {
'CropRect': ((479,50), 197, 250),
'Mode': App.Constants.CropMode.Custom,
'Units': App.Constants.CropUnits.Inches,
'SelectedArea': False,
'PrintWidth': -1,
'PrintHeight': -1,
'CropAsNewImage': False,
'RotationAngle': -0,
'AutoFit': False,
# ResizeCanvas
App.Do( Environment, 'ResizeCanvas', {
'AspectRatio': 0.788,
'FillColor': (255,255,255),
'HoriPlace': App.Constants.HorizontalType.Custom,
'MaintainAspect': False,
'NewDimUnits': App.Constants.UnitsOfMeasure.Pixels,
'NewHeight': 800,
'NewWidth': 800,
'PlaceBottom': 275,
'PlaceLeft': 553,
'PlaceRight': 50,
'PlaceTop': 275,
'VertPlace': App.Constants.VerticalType.Center,
# PasteAsNewSelection
App.Do( Environment, 'PasteAsNewSelection', {
'Offset': (-129,30),
# Eyedropper
App.Do( Environment, 'Eyedropper', {
'Point': (624.5,379.5),
'SampleSize': 0,
'Material': App.Constants.MaterialRef.Foreground,
'ActiveLayerOnly': False,
'SampleColor': 0,
'CopyStyleAndFill': False,
# Color Changer
App.Do( Environment, 'ColorChanger', {
'Tolerance': 35,
'Antialias': 5,
'PointList': [(303.5,357.5)],
# ColorChangerFixup
App.Do( Environment, 'ColorChangerFixup', {
'ExecutionMode': App.Constants.ExecutionMode.Silent,
# FileClose
App.Do( Environment, 'FileClose', {
# SelectDocument
App.Do( Environment, 'SelectDocument', {
'SelectedImage': 0,
'Strict': False,
Thank you for any help
cosmicDread
motherboard: MSI MPG Z390 Gaming PRO
processor: Intel Core i9-9900K
ram: 32 GB
Video Card: GeForce GTX 1080 Ti
Hard_Drive_Capacity: 6 TB
Monitor/Display Make & Model: Acer Predator X34
Corel programs: PaintShop X5, X6, X8, X9, '18, '19, '20
Re: Use Foreground Color In ColorChanger
Post by cosmicDread »
Pahrump,
From my experience, I've used the GetMaterial command to get the eyedropper color which is placed in the foreground color.
Code: Select all
    # Get color from Eyedropper which is in the foreground (IsPrimary: 1):
    material_dict = App.Do(Environment, 'GetMaterial', {
            'IsPrimary': 1,
    # The color is RGB:
    color = material_dict['Color']
    # Color Changer
            'Color': color,
            'Tolerance': 35,
            'Antialias': 5,
Eyedropper to Color Changer.zip
The above code has been added to the script.
(1.12 KiB) Downloaded 108 times
:idea:
Charles
When the majority of the people on Earth are wanting the Galactic Federation to show themselves, then they will.
Pahrump
Post by Pahrump »
Thank you, that worked. I'd like to buy you a coffee if we can figure out how to communicate.
cosmicDread
ram: 32 GB
It was my pleasure. I'm glad it works.
