flood fill - one pixel residua
rnmerchant
motherboard: Gigabyte
processor: AMD Ryzen 5
ram: 16gb
Hard_Drive_Capacity: 5tb
Monitor/Display Make & Model: LG x 2
Corel programs: PSP; Draw
Post by rnmerchant »
I have some pictures that I've corrected abnormal rotation (they were scanned crookedly from a book).
When I straighten them (and don't auto-crop) the new/leftover space is black. Now, I choose a background color and go to fill the black areas.
However there is a one-pixel strip (stepped, as the line isn't horizontal/vertical) of residual black pixel. It has not been replaced.
With my light choice in fill color, it should be considered very different and be replaced. Why is it not?
Thanks Richard
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: flood fill - one pixel residua
Post by LeviFiction »
Most likely the anti-aliasing that happens when the edges get rotated. I can offer you two possible options
1) Increase the tolerance of the flood fill tool
or
2) PSP uses the background color on the materials palette to fill in the corners. So, on the materials palette, before you straighten the image, select a background color that you want. This will be the color that gets filled in at the corners.
So if I want white to be filled in on the corners, I choose white as my background color. If I want teal, i use that as my background color. I believe it's filling in black because you have black set as your background color on the materials palette.
rnmerchant
ram: 16gb
Sounds good! Thanks
Richard
